Hi everyone,
So I am interested in to upgrading my MOBO and CPU, I currently have GA-970A-D3 mobo and an AMD FX8120 black edition, with a resent OC to 3.9, I have for cooling a Hyper EVO 212
My GPU (I know is making a bottle neck, I got a great deal that couldn't let go) GTX 970 and I have 8 GB ram of Hyper X
Any recommendations, on what to get or how to proceed, I really want a mobo with chipset 990fx, like GA-990FXA-UD3 R5, and maybe upgrading to a AMD FX 8320, but I am not sure.
The PC will be use for gaming only
https://linustechtips.com/topic/565360-mobo-and-cpu-upgrade/
GA-990FXA-UD3 R5 and a 8350 black, would not be bottle-necked by a 970 in most games. the 212 if not going hard on the oc, should be fine. if you are looking to go bigger than the 8350, then just go to intel as the price to preformance even with oc'ing isnt there. Cheers ~
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128859&cm_re=GA-990FXA-UD3_R5-_-13-128-859-_-Product < mobo
http://www.newegg.com/Product/Product.aspx?Item=N82E16819113284        < Cpu
 Pc Speck's : i7-6700K 4.0GHz , GTX 980 Ti G1 Gaming 6GB , 16 GB Corsair Vengance DDR4 - 3400 , ROG SWIFT PG278Q 144Hz , (2) Acer G277HL bid 60Hz.
https://linustechtips.com/topic/565360-mobo-and-cpu-upgrade/#findComment-7430340
If you're doing gaming only, then right now going with AMD is a really bad choice. AMD is currently suited for workstation tasks with their high multi-threaded performance, but poorly suited to thread limited tasks like gaming with their poor single-threaded performance due to their old, aging architecture.
Get this:
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($224.99 @ SuperBiiz)
Motherboard: ASRock Z97 PRO3 ATX LGA1150 Motherboard  ($80.98 @ Newegg)
Total: $305.97
Generated by PCPartPicker 2016-03-14 12:40 EDT-0400
If that's out of budget, then you can get this:
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($174.89 @ OutletPC)
Motherboard: Gigabyte GA-B85M-DS3H Micro ATX LGA1150 Motherboard  ($56.99 @ SuperBiiz)
Total: $231.88
Generated by PCPartPicker 2016-03-14 12:47 EDT-0400
The cheaper locked i5 will beat even an FX-9590 in gaming.
Also, if you're planning on getting new ram, then going skylake is the correct choice. I stuck with haswell though because I didn't think you were interested in swapping memory.
https://linustechtips.com/topic/565360-mobo-and-cpu-upgrade/#findComment-7430341
2 minutes ago, Matt100HP said:
If you're going to upgrade your mobo and CPU, get an i5 4690k or, if you're willing to also buy DDR4 RAM, i5 6600k.
Well the reason is that I am on a budget, so going with an Inter processor, will go a little over the mark
https://linustechtips.com/topic/565360-mobo-and-cpu-upgrade/#findComment-7430351
You should not grab a 990FX board if you are on a budget a 970 board with better VRMs is a better idea and OC the FX-8120 further or you can go for a FX-6300 if you do not need much more multi threaded performance that is... :) (also what game has the bottleneck?)
Zen-III-X8-5900X (Gamestation 5)
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Ryzen 5 3600, 6-cores, 12-threads, 4.2/4.2GHz, 35,3MB cache (T.S.M.C. 7nm FinFET) / CPU: AMD Ryzen 9 5900X, 12(8)-cores, 24(16)-threads, 4.5/4.8GHz, 70.5MB(68,35MB) cache (T.S.M.C. 7nm FinFET) / Display: HP 24" L2445w (64Hz OC) 1920x1200 / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: ASUS Radeon RX 6600 XT DUAL OC RDNA2 32CUs @2.6GHz 10.6 TFLOPS (T.S.M.C. 7nm FinFET) R.ID (NimeZ drivers) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: ASRock B450M Pro4, Socket-AM4 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W / RAM A1 & B1: G.SKILL DDR4-3600MHz CL18-20-21-39-60-1T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: HyperX DDR4-3600MHz CL16-18-19-37-85-1T "SK Hynix 8Gbit CJR" (2x16GB) / Operating System: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Western Digital My Passport 2.5" 2TB HDD / Storage 4: Western Digital Elements Desktop 2TB HDD / Storage 5: Kingston A2000 1TB M.2 NVME SSD / Wi-fi & Bluetooth: ASUS PCE-AC55BT Wireless Adapter (Intel)
 Lake-V-X6-10600 (Gaming PC)
R23 score MC: 9190pts | R23 score SC: 1302pts
R20 score MC: 3529cb | R20 score SC: 506cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: Intel Core i5-10600(ASUS Performance Enhancement), 6-cores, 12-threads, 4.4/4.8GHz, 13,7MB cache (Intel 14nm++ FinFET) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: Gigabyte Radeon RX Vega 56 Gaming OC GCN5 56CUs @1.7GHz 12.19 TFLOPS (Samsung 14nm FinFET) R.ID (NimeZ drivers) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: ASUS PRIME B460 PLUS, Socket-LGA1200 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W / RAM A1 & B1: HyperX DDR4-2666MHz CL13-15-15-30-45-2T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: Juhor DDR4-3200MHz CL16-20-20-38-72-2T "SK Hynix 8Gbit MFR" (2x16GB) / Operating System: Windows 10 Home / Sound: Zombee Z300 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Seagate® Barracuda 2TB HDD / Storage 4: Seagate® Desktop 2TB SSHD / Storage 5: Crucial P1 1000GB M.2 SSD/ Storage 6: Western Digital WD7500BPKX 2.5" HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter (Qualcomm Atheros)
Vishera-X8-9370 | R20 score MC: 1476cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Case Fan VRM: SUNON MagLev KDE1209PTV3 92mm / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: AMD FX-8370 (Base: @4.4GHz | Turbo: @4.7GHz) Black Edition Eight-Core (Global Foundries 32nm) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: Gigabyte Radeon RX Vega 56 Gaming OC @1501MHz (Samsung 14nm FinFET) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: MSI 970 GAMING, Socket-AM3+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W PSU / RAM 1, 2, 3 & 4: Corsair Vengeance DDR3-1866MHz CL8-10-10-28-37-2T (4x4GB) 16.38GB / Operating System 1: Windows 10 Home / Sound: Zombee Z300 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Seagate® Barracuda 2TB HDD / Storage 3: Seagate® Desktop 2TB SSHD / Wi-fi: TP-Link TL-WN951N 11n Wireless Adapter
Godavari-X4-880K | R20 score MC: 810cb
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 95w Thermal Solution / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Athlon X4 860K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / CPU: AMD Athlon X4 880K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / Display: HP 19" Flat Panel L1940 (75Hz) 1280x1024 / GPU: EVGA GeForce GTX 960 SuperSC 2GB (T.S.M.C. 28nm) / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: MSI A78M-E45 V2, Socket-FM2+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W PSU / RAM 1, 2, 3 & 4: SK hynix DDR3-1866MHz CL9-10-11-27-40 (4x4GB) 16.38GB / Operating System 1: Ubuntu Gnome 16.04 LTS (Xenial Xerus) / Operating System 2: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Western Digital My Passport 2.5" 2TB HDD / Storage 3: Western Digital Elements Desktop 2TB HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter
Acer Aspire 7738G custom (changed CPU, GPU & Storage)
CPU: Intel Core 2 Duo P8600, 2-cores, 2-threads, 2.4GHz, 3MB cache (Intel 45nm) / GPU: ATi Radeon HD 4570 515MB DDR2 (T.S.M.C. 55nm) / RAM: DDR2-1066MHz CL7-7-7-20-1T (2x2GB) / Operating System: Windows 10 Home / Storage: Crucial BX500 480GB 3D NAND SATA 2.5" SSD
Complete portable device SoC history:
Apple A4 - Apple iPod touch (4th generation)
Apple A5 - Apple iPod touch (5th generation)
Apple A9 - Apple iPhone 6s Plus
HiSilicon Kirin 810 (T.S.M.C. 7nm) - Huawei P40 Lite / Huawei nova 7i
Mediatek Dimensity 700 (T.S.M.C 7nm) - Cherry Mobile Aqua S10 Pro 5G
Mediatek MT2601 (T.S.M.C 28nm) - TicWatch E
Mediatek MT6580 (T.S.M.C 28nm) - TECNO Spark 2 (1GB RAM)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (orange)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (yellow)
Mediatek MT6735 (T.S.M.C 28nm) - HMD Nokia 3 Dual SIM
Mediatek MT6737 (T.S.M.C 28nm) - Cherry Mobile Flare S6
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (blue)
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (gold)
Mediatek MT6750 (T.S.M.C 28nm) - honor 6C Pro / honor V9 Play
Mediatek MT6765 (T.S.M.C 12nm) - TECNO Pouvoir 3 Plus
Mediatek MT6797D (T.S.M.C 20nm) - my|phone Brown Tab 1
Qualcomm MSM8926 (T.S.M.C. 28nm) - Microsoft Lumia 640 LTE
Qualcomm MSM8974AA (T.S.M.C. 28nm) - Blackberry Passport
Qualcomm SDM710 (Samsung 10nm) - Oppo Realme 3 Pro
https://linustechtips.com/topic/565360-mobo-and-cpu-upgrade/#findComment-7430365
Save up some more money, spending all that cash on an AMD CPU and associated mobo is not worth it for a gaming machine. Keep the machine you have until you can afford an Intel based system with either a 4690k or a 6600k.
https://linustechtips.com/topic/565360-mobo-and-cpu-upgrade/#findComment-7430372
Did you look at my cheaper intel build? It's literally $15 more expensive than the cheapest AMD FX-8 cpu/mobo combo that doesn't have shit VRMs, which would be this:
CPU: AMD FX-8320 3.5GHz 8-Core Processor  ($139.41 @ NCIX US)
Motherboard: Gigabyte GA-970A-UD3P ATX AM3+ Motherboard  ($109.99 @ NCIX US)
Total: $218.99
Generated by PCPartPicker 2016-03-14 12:49 EDT-0400
And that's the 8320, not even the 8350. The i5-4460 spanks these CPUs, and even at stock clocks beats an OC'd FX-9590 in gaming benchmarks.
That's around 5% more in price for nearly 60% more performance. I can't imagine not doing it since your only specified purpose is gaming.
https://linustechtips.com/topic/565360-mobo-and-cpu-upgrade/#findComment-7430381
Or Zen when it comes in Q4 of 2016! :P
https://linustechtips.com/topic/565360-mobo-and-cpu-upgrade/#findComment-7430384
Or Zen, if it ends up being competitive with Intel CPUs for gaming purposes, which hopefully it does. However, as it stands at the moment, the sensible choice for high end gaming is an unlocked i5 based system, in my opinion.
https://linustechtips.com/topic/565360-mobo-and-cpu-upgrade/#findComment-7430396
I am happy with my FX-8370 but I am not playing anything that is problematic such as Arma, DayZ or Dying Light! :P
https://linustechtips.com/topic/565360-mobo-and-cpu-upgrade/#findComment-7430407
Get this:
Total: $305.97
Total: $231.88
Hey I didn't see this comment, I have check this builds, and they do not look bad, I like better the build with the i5 4690k, but it may be hard to find that mobo, I have a loot of troubles to get things sent to Mexico, but I will look for it, do you have any other recommendations?
https://linustechtips.com/topic/565360-mobo-and-cpu-upgrade/#findComment-7430582
 Any Z97 chipset board will do. I only selected that one because it was the cheapest here. The different market really changes things, and I have no way of suggestion exact parts since I don't know your local prices.
https://linustechtips.com/topic/565360-mobo-and-cpu-upgrade/#findComment-7430780
