For the most part, this is what I've had for the past couple of years:
http://pcpartpicker.com/p/xjzd7P
I'm actually wanting to switch over to the green team. Let's say my budget is $800-$900 and I primarily use this for gaming. What are my best options for upgrading? My focus of course is cpu, mobo, and gpu. I've been eyeing the 4790k, but as much as I try to research, should I roll with that or does it make more sense to go with skylake in the long run? Of course, this isn't my only worry, but we'll start with that.
https://linustechtips.com/topic/564992-need-upgrading-help/
PCPartPicker part list: http://pcpartpicker.com/p/GZt63C
Price breakdown by merchant: http://pcpartpicker.com/p/GZt63C/by_merchant/
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($219.99 @ Micro Center)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($25.75 @ OutletPC)
Motherboard: Asus Z170-A ATX LGA1151 Motherboard  ($153.99 @ SuperBiiz)
Memory: Kingston HyperX Fury Black 8GB (2 x 4GB) DDR4-2133 Memory  ($39.99 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($88.00 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.89 @ OutletPC)
Video Card: EVGA GeForce GTX 960 2GB SuperSC ACX 2.0+ Video Card  ($169.99 @ NCIX US)
Case: NZXT S340 (Black) ATX Mid Tower Case  ($63.99 @ SuperBiiz)
Power Supply: EVGA SuperNOVA G2 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($78.99 @ SuperBiiz)
Total: $890.58
Generated by PCPartPicker 2016-03-13 19:00 EDT-0400
Novus Anima
CPU - 4670K @ 4.2 GHz | Motherboard - ASUS Z97-PRO | CPU Cooler - Corsair H105
RAM - Corsair Vengeance (4x4GB) | GPU - EVGA GTX 1060 SSC
Storage - Samsung M.2 64GB SSD, PNY 240GB SSD , WD 1TB Caviar Blue, WD 500GB HDD
PSU - EVGA 650W G2 | Peripherals - Logitech G710, Logitech G602
Laptops
MacBook Pro Mid-2011
Surface Pro 3
https://linustechtips.com/topic/564992-need-upgrading-help/#findComment-7426874
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($329.99 @ SuperBiiz)
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler  ($34.50 @ Newegg)
Motherboard: Asus Z97-A ATX LGA1150 Motherboard  ($139.99 @ SuperBiiz)
Memory: G.Skill Sniper Series 8GB (2 x 4GB) DDR3-1866 Memory  (Purchased For $0.00)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  (Purchased For $0.00)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  (Purchased For $0.00)
Video Card: Sapphire Radeon R9 390 8GB Nitro Video Card  ($309.99 @ SuperBiiz)
Case: NZXT Source 210 Elite (White) ATX Mid Tower Case  (Purchased For $0.00)
Power Supply: EVGA SuperNOVA P2 650W 80+ Platinum Certified Fully-Modular ATX Power Supply  ($69.99 @ NCIX US)
Total: $884.46
Generated by PCPartPicker 2016-03-13 19:04 EDT-0400
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/564992-need-upgrading-help/#findComment-7426888
1 hour ago, BigBootyLilCooty said:
You don't need to spend more than like 600 if all you're doing is gaming and doing it at 1080p
The 7870 is still a more than capable card for 1080p, and nvidia's current mid range can't really measure up against the AMD cards factoring in DX12/Vulkan support in the near future and an adaptive sync display, namely the 380 > 960 and 390>970
spend the rest on upgrading your display or something, what's your current display?
PCPartPicker part list: http://pcpartpicker.com/p/wXdHkL
Price breakdown by merchant: http://pcpartpicker.com/p/wXdHkL/by_merchant/
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($189.99 @ SuperBiiz)
Motherboard: Gigabyte GA-H110M-S2HP Micro ATX LGA1151 Motherboard  ($71.38 @ Newegg)
Memory: G.Skill NT Series 8GB (1 x 8GB) DDR4-2400 Memory  ($29.99 @ Newegg)
Video Card: PowerColor Radeon R9 380 4GB PCS+ Video Card  ($208.89 @ OutletPC)
Case: Fractal Design Core 1000 USB 3.0 MicroATX Mid Tower Case  ($34.99 @ Micro Center)
Power Supply: EVGA 600B 600W 80+ Bronze Certified ATX Power Supply  ($49.99 @ Newegg)
Total: $635.12
Generated by PCPartPicker 2016-03-13 20:24 EDT-0400
https://linustechtips.com/topic/564992-need-upgrading-help/#findComment-7427273
