Hi LTT,
I recently purchased a Siberia V3 headet and like it alot so far but I have one issue.
While the headset a continuous ticking sound can be heard. Its hard to explain but its a soft doof doof doof. It can't be heard while gaming and listening to music but whenever no sound is being produced I have this noise.
Could it be that my NZXT H440 has a fried audio jack in the front? I haven't used the ports on the motherboard because I can't seem to get the mic to work when using the mobo ports.
Please help me solve!
https://linustechtips.com/topic/564947-siberia-v3-issues/
I would recommend that you atleast try the ports in the back. The front ports are quite prone to interference, so using the back I/O will eliminate that as a factor.
Are you sure you plugged the headset into the right ports on the back?
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
https://linustechtips.com/topic/564947-siberia-v3-issues/#findComment-7426403
use the back ports, my front ports with my old case had a lot of interferance
Builds:
https://linustechtips.com/topic/564947-siberia-v3-issues/#findComment-7426463
