Hey guys,
I am pretty paranoid when it comes to power supplies. "What if the wattage is not enough for stock and overclocking performances?" "What if the quality is not good enough?" You get the point.
May I have some feedback on the choice of my power supply? http://uk.pcpartpicker.com/p/PBKHYJ
Thanks.
https://linustechtips.com/topic/564737-power-supply-purchase/
1 minute ago, Manolis said:
Hey guys,
Thanks.
https://linustechtips.com/topic/564737-power-supply-purchase/#findComment-7424372
1 minute ago, Oshino Shinobu said:
You can get an EVGA G2 for around the same price, but is much, much better quality. Also, you could run the system on 550W.
http://uk.pcpartpicker.com/part/evga-power-supply-220g20650y1
Does your 550W estimate include overclocking performance?
https://linustechtips.com/topic/564737-power-supply-purchase/#findComment-7424376
With a good quality unit, yes. If you want to be safe, the 650W G2 is a very good option. Excellent quality and more than enough power.
https://linustechtips.com/topic/564737-power-supply-purchase/#findComment-7424381
Get a decent 550W or 600W if you are really that afraid
https://linustechtips.com/topic/564737-power-supply-purchase/#findComment-7424402
12 minutes ago, Manolis said:
Hey guys,
Thanks.
after the 3rd or 4th post you're still stuck with the cx750 lol
trust me, your system wont consume more than 500W even if you overclock, so dont worry about getting a 500~600W RELIABLE PSU
i recommend the EVGA Supernova G2 550W :D its more than enough for you and its VERY reliable
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/564737-power-supply-purchase/#findComment-7424416
Hahaha, I just try to explore all options before I get my parts. Doesnt hurt, does it? :)
https://linustechtips.com/topic/564737-power-supply-purchase/#findComment-7424419
well if you want to have more choices, you can check this list
pick something from tier 1 or atleast, tier 2
then check jonnyguru for reviews about it and see the pros and cons before you pull the trigger
https://linustechtips.com/topic/564737-power-supply-purchase/#findComment-7424428
JohnyGuru is a double-edged blade. He rates based on price hence why the VS get a 7/10 whereas they deserve a 3/10
https://linustechtips.com/topic/564737-power-supply-purchase/#findComment-7424432
I personally just use the forum´s own list. Seem´s more comprehensive to me:
https://linustechtips.com/topic/564737-power-supply-purchase/#findComment-7424434
Getting a 650 gold would be better I think.
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/564737-power-supply-purchase/#findComment-7424507
50 minutes ago, Manolis said:
Hey guys,
Thanks.
you could get a better one.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/564737-power-supply-purchase/#findComment-7424547
2 hours ago, Manolis said:
Hey guys,
Thanks.
yeah, bad choice.
750W is plenty but a better-quality unit would be worth it. Check out EVGA's B2/GS/GQ/G2 series, 550W and up.
https://linustechtips.com/topic/564737-power-supply-purchase/#findComment-7425104
