So if I have my BIOS settings to where it uses IGD it boots up no problem. Using this method allowed me to fix the issue where my GPU wasn't showing up in order for me to update the driver, which I thought would solve the issue of it not posting from PEG. But for whatever reason,the system till won't post if I set it to PEG unless I remove my GPU entirely.
Specs:
i7 6700k
MSI Z170 SLI PLUS
EVGA SUPERNOVA 750G2 80+ Gold Efficiency
Corsair H100i GTX AIO Water Cooler
EVGA GTX 980ti Hybrid
OS is Windows 10
https://linustechtips.com/topic/564489-system-wont-post-when-set-to-peg/
Is the iGPU enabled when the dGPU is plugged in? It is usually disabled automatically when a dGPU is detected, and thus you won't get any video output from the motherboard i/o panel.
AMD Ryzen 7800 X3D, MSI B650 Project Zero, Antec C5, Gigabyte RTX 4080 Super Aero
Nikon D500 | Nikon 300mm f/4 PF  | Nikon 200-500 f/5.6 | Nikon 50mm f/1.8 | Tamron 70-210 f/4 VCII | Sigma 10-20 f/3.5 | Nikon 17-55 f/2.8 | Tamron 90mm F2.8 SP Di VC USD Macro | Neewer 750II
