whats your operating system. whats the RAM, whats its speed? Is it 4x 8GB sticks? or 8x 4GB sticks? Whats your motherboard?
We need more info.
Gaming - Ryzen 9800X3D | 64GB 6400mhz cl30 9070 XT
Homelab - many servers...constantly changing.
3970X/256GB - 5950X/128GB ECC - 5600G/96GB - 3400GE/16GB - 3400GE/16GB
https://linustechtips.com/topic/564448-need-help-ram-issue/#findComment-7421710
Just now, hman12311 said:
windows 10 32 bit its that the prob i think i might be
thats your problem. 32 bit operating systems limit you to 4GB of RAM.
https://linustechtips.com/topic/564448-need-help-ram-issue/#findComment-7421724
That's correct, the 32bit version of Windows 10 has a limit of 4GB RAM.
6600k @ 4.5 GHz | SLI reference 980Ti's | 8GB Kingston DDR4 @ 2666MHz | Asus Z170-A mobo | PG279Q Monitor
https://linustechtips.com/topic/564448-need-help-ram-issue/#findComment-7421728
32bit windows is limited to a max of 4gbs of ram.
CPU: i5 6600k OCed to 4.5Ghz @ 1.35v, GPU: R9 390 Nitro, Motherboard: Asus z170-A, CPU Cooler: H100i GTX, RAM: HyperX 2x8 16gb DDR4, PSU: Seasonic x650, Storage: 850 EVO 500gb, WD 1tb blue, Case: H440 White/Black
https://linustechtips.com/topic/564448-need-help-ram-issue/#findComment-7421748
4 minutes ago, hman12311 said:
if i get the 64 bit will it work
Well what are your entire specs as your processor might not even support 64bit,
https://linustechtips.com/topic/564448-need-help-ram-issue/#findComment-7421753
no i can support a 64 bit
Ok then 64bit windows should allow you to use all 32gbs of ram.
https://linustechtips.com/topic/564448-need-help-ram-issue/#findComment-7421763
