2 minutes ago, Rauno727 said:
I need help with my pc. Having shutdown issues, I need to clear CMOS and reset Bios to start my OS.
My pc spec:
motherboard: MSI - MS-7276
CPU: Intel Celeron 2.30 Ghz
GPU: CLUB3D CGNX-G5224LI NVIDIA GeForce GT 520 1GB
Thanks!
Try running the pc without the graphics card and see if that works. If that doesnt work then try different ram, it might be trying to overclock itself automatically i don't know xD
CPU: Ryzen 5 5600x 4.9Ghz PBO    SSDs: 250GB 850 Pro           STEAM: KezzaMcFezza
GPU: GTX 1070 Strix                                     250GB 970 Pro           MOBO: MSI MPG B550 Gaming Plus
HDD: 1TB WD Black Drive                             500GB 860 Evo          MOUSE: Logitech G502
https://linustechtips.com/topic/564153-having-shutdown-issues/#findComment-7418352
My pc spec:
Thanks!
Or your operating system really doesn't like you and then you should try a clean install of windows :P
https://linustechtips.com/topic/564153-having-shutdown-issues/#findComment-7418376
