5x1 monitor stand?
OddsCrazyStuff
Any suggestion where to find a monitor stand that can support this setup?
The original stands works, but its a pain to try and align them according to each other.
I want it to be standing on the desk and not mounted to the desk, since I cant drill in it and the edge is too far away from where I'm sitting.
I'm fine with a combo solution, where 2 or more stands are put together to make 1 big one, as long as its acts like one unit once done.
5x1 27"
P1020280.thumb.JPG.c27ecb815a986e2d8eb3f
I speak my mind, sorry if thats a problem.
Unfortunately I can't help but I must say..
That looks incredible O.o
I don't like 2D games...I just couldn't get into them.. ( ͡° ͜ʖ ͡°)
I'm not the first one to want a 5 monitor setup, so there has to been someone out there that have made a solution for me.
4 minutes ago, Prysin said:
you make it yourself... like i had to do for my 32 + 34" screens.
Yeah, I guess there is the DIY approach. I just need to figure out where the monitors needs to be in relation to each other first (how little or much angle I want/need between them).
my setup cost about 80 bucks.... the closets monitor stand i could find supporting the size and weight of my monitors would have cost my 425 USD
With several 1000$ worth of monitors, so is it not that much of a problem to pay for a proper stand.
But what I guess I will end up doing, is getting 2x 3 monitor stands and find a way to join them together.
Since it seems that not enough people want my setup for any company to make it (closest I found was for 24").
