So im using a Reference 980 TI from EVGA, its great and all but i cant seem to push it past 115Mhz on the overclock and keep it stable eaven tho at 145 Mhz it did fine in Valley for a bit over an hour but when i play Rise of the tomb raider for an hour or less it useally crashes, am i doing something wrong? I have 0+ mv, 110% power limit, 115+ on core clock and 200+ on memory clock atm (too keep it stable for longer in RotTR, havent tested it yet in other games) but i have seen people push theirs up to 210+ mhz on the core and 300+ on the mem clock...have i just lost the sillicone lottery? or is there something else im forgetting?
https://linustechtips.com/topic/564094-reference-980-ti/
you can try raising the core voltage, if an overclock is unstable you might wanna check the temp, power, and volt limit, and eliminate the limit by raising the bar
and also, being stable in valley doesnt mean it will be in games, different workload will have different consequences on your card
if all else fails, you just got a mild overclocker :D but dont feel bad, the 980ti still stomps over 95~99% of the gaming community anyways lol
-sigh- feeling like I'm being too negative lately
https://linustechtips.com/topic/564094-reference-980-ti/#findComment-7417789
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
https://linustechtips.com/topic/564094-reference-980-ti/#findComment-7417798
5 minutes ago, Praesi said:
Thanks for the video, but i have seen it and all my knowledge of OC of GFX comes from Jay, this was more a question: is this normal, considering how diffrent it is from other peoples results
https://linustechtips.com/topic/564094-reference-980-ti/#findComment-7417828
You need more voltage
https://linustechtips.com/topic/564094-reference-980-ti/#findComment-7417839
well yeah, i have tried adding more mV, but didnt really see any diffrence, but i left it at 0 mV because most people didnt really need to add voltage to it at all, which was great to not hassle with =)
https://linustechtips.com/topic/564094-reference-980-ti/#findComment-7417840
And temps never go beyond 83C
https://linustechtips.com/topic/564094-reference-980-ti/#findComment-7417843
well you can check if adding voltage raised the actual voltage, coz my card's voltage doesnt rise even though i pushed the slider to the max
https://linustechtips.com/topic/564094-reference-980-ti/#findComment-7417846
Just now, Kobolobob said:
i tried adding more voltage but it did not really make a diffrence, still crashed at 145 Mhz in Tomb raider in around 1 hr
Max voltage and power sliders and keep temps under 80*C
https://linustechtips.com/topic/564094-reference-980-ti/#findComment-7417854
Pushed the slider to max, 91C
it overheated that's your issue, Max temp for Maxwell is 85*C
https://linustechtips.com/topic/564094-reference-980-ti/#findComment-7417857
I will try to play around more when i come home from work, but atm it just seems i got a bit daft and lazy overcloking card =)
Max the fan. Heat is your issue
https://linustechtips.com/topic/564094-reference-980-ti/#findComment-7417860
Anyway arent Nvidia cards rated to run at at least 90C "comfortably"?
85*C max
https://linustechtips.com/topic/564094-reference-980-ti/#findComment-7417873
23 minutes ago, Kobolobob said:
Still havent hit 85C on my card, peaked at 83C once or twice
high temps = more chance of instability.
https://linustechtips.com/topic/564094-reference-980-ti/#findComment-7417953
43 minutes ago, Kobolobob said:
ill try increasing the fanspeed to max and see if it improves, maybe find a way to get more air into the case
Don't bother. 980 Ti is powerful enough as it is. Drop the OC altogether so as to increase the lifespan of the card. Nvidia reference cards simply run too hot for OCing
https://linustechtips.com/topic/564094-reference-980-ti/#findComment-7418159
