So I just got a h100i so I decided I wanted to overclock my CPU. Highest overclock I can get it without going over 1.4 volts was 4.5 gigahertz is this good it seems to be fairly stable at 1.375 volt and 4.5 gigahertz. At 4.6 gigahertz and 1.4 volts at blue screens almost instantly when I start rendering a video
https://linustechtips.com/topic/564013-oc-help/
what was voltage on 4.3 and 4.4?
turn the RAM to default (2133), but use the 2666 timings and voltage.
find the VCCIO voltage (prolly AUTO) and up the voltage to 1.8500v for now to see if stability returns.
once you get your CPU dialed in, then you can proceed to move the RAM speed back to 2666.
https://linustechtips.com/topic/564013-oc-help/#findComment-7416955
i dont remember what voltage i could got at 4.3 and 4.4.
so ill try to turn the ram to default and fix the vccio so i can oc it higher to like 4.6-7?
https://linustechtips.com/topic/564013-oc-help/#findComment-7416975
1 hour ago, KSores said:
are you sure? that is over double the voltage it is set at currently (default)
Sweet christ do not do that! I think he's confused with VCCIN and Haswell @airdeano
Follow this guide:
http://www.overclock.net/t/1570313/skylake-overclocking-guide-with-statistics
Keep sys agent and VCCIO under 1.25 and ~1.225 respectively.
LanSyndicate Build | i5-6600k | ASRock OC Formula | G.Skill 3600MHz | Samsung 850 Evo | MSI R9-290X 8GB Alphacool Block | Enthoo Pro M | XTR Pro 750w | Custom Loop |
Daily | 5960X | X99 Sabertooth | G.Skill 3000MHz | 750 NVMe | 850 Evo | x2 WD Se 2TB | x2 Seagate 3TB | Sapphire R9-290X 8GB | Enthoo Primo | EVGA 1000G2 | Custom Loop |
Game Box | 4690K | Z97i-Plus | G.Skill 2400MHz | x2 840 Evo | GTX 970 shorty | Corsair 250D modded with H105 | EVGA 650w B2 |
https://linustechtips.com/topic/564013-oc-help/#findComment-7417197
