Radiator Thickness Help
Go to solution Solved by W-L,
14 hours ago, HeroXLazer said:
So then why do they make different sizes?
Thickness does help but is marginal compared to longer rads and cheaper, where you can have a 60mm thick 240mm rad a 30mm thick 360mm will out perform it. The difference a thick rad makes is usually only at most 5C at load to a thin one, there are other factors also like FPI (fins per inch).
there is very little temp difference with thickness
its much more effective to get larger radiators or more of them
https://linustechtips.com/topic/563937-radiator-thickness-help/#findComment-7416063
https://linustechtips.com/topic/563937-radiator-thickness-help/#findComment-7416203
They make the thick Rads because some cases only hold say a 240mm Rad. But it can be as thick as it wants to be. So it's another way to have more surface area when length is an issue.
I7 5820k, Asus X99 Sabertooth, 980Ti Classified, 32gb Gskill Ripjaws 4, Corsair Rm1000i, Samsung 950 Pro, Custom Loop Xspc Cpu Block Ek Gpu Block, Windows 10, Define S. Acer Predator XB271HU
https://linustechtips.com/topic/563937-radiator-thickness-help/#findComment-7417893
