2 minutes ago, norain said:
 i was wondering if there was a way that i could run a second mobo using a pcie because i work with vfx and that is very CPU intensive so i was considering to buy a second hand zeon and add it to my i7 6700k
not possible, but you could make a seperate rendering server, this offloads the rendering of the final product so you can work on other things on your 6700k while that xeon is rendering :)
https://linustechtips.com/topic/563591-using-2-mobos/#findComment-7411996
but would it be possible to attach it through the pcie so as to transfer that data so that its only a mobo CPU cooler and ram?
https://linustechtips.com/topic/563591-using-2-mobos/#findComment-7412012
What you're describing sounds like Intel's Phi coprocessors. They are essentially extra processors that you can slot in PCIe. Hugely expensive though and not really meant for home use. To answer your specific question though no, you can't connect two motherboards like that.
~ Specs bellow ~
Windows 10 Pro 64-bit [UEFI]
CPU: Intel i7-5820k Haswell-E @ 4.5-4.7Ghz (1.366-1.431V) | CPU COOLER: Corsair H110 280mm AIO w/ 2x Noctua NF-A14 IPPC-2000 IP67 | RAM: G.Skill Ripjaws 4 32Gb (8x4Gb) DDR4 @ 2666mhz CL15 | MOBO: MSI X99S Gaming 7 ATX | GPU: MSI GTX 1080 Gaming (flashed "X") @ 2138-2151Mhz (locked 1.093V) | PSU: Corsair HX850i 850W 80+ Platinum | SSD's: Samsung Pro 950 256Gb & Samsung Evo 850 500Gb | HDD: WD Black Series 6Tb + 3Tb | AUDIO: Realtek ALC1150 HD Audio | CASE: NZXT Phantom 530 | MONITOR: LG 34UC79G 34" 2560x1080p @144hz & BenQ XL2411Z 24" 1080p @144hz | SPEAKERS: Logitech Z-5450 Digital 5.1 Speaker System | HEADSET: Sennheiser GSP 350 | KEYBOARD: Corsair Strafe MX Cherry Red | MOUSE: Razer Deathadder Chroma | UPS: PowerWalker VI 2000 LCD
Mac Pro 2,1 (flashed) OS X 10.11.6 El Capitan 64-bit (NAS, Plex, HTTP Server, Game Servers) [R.I.P]
CPUs: 2x Intel Xeon X5365 @ 3.3Ghz (FSB OC) | RAM: OWC 16Gb (8x2Gb) ECC-FB DDR2 @ 1333mhz | GPU: AMD HD5870 (flashed) | HDDs: WD Black Series 3Tb, 2x WD Black Series 1Tb, WD Blue 2Tb | UPS: Fortron EP1000
https://linustechtips.com/topic/563591-using-2-mobos/#findComment-7412017
no, use your network for data transfer and build a whole new second pc
9800X3D - NH-D15S - MSI X670E  -  32GB 6000MHz CL30 - RTX 3080 FTW3 - 970evo 1TB - 980pro 1TB - 970evo 1TB - 970evo+ 2TB -  970evo+ 2TB - 850evo 250GB - WDblack 1TB - WDblue 3TB - HX850i -  27GR95QE-B.AEU - 28MQ780-B - 27GP850-B - 27GL850 - Meshify 2
https://linustechtips.com/topic/563591-using-2-mobos/#findComment-7412024
so lan would be the only option for fast data transfer
https://linustechtips.com/topic/563591-using-2-mobos/#findComment-7412030
Yes, gigabit ethernet is your best bet.
~ Specs bellow ~
https://linustechtips.com/topic/563591-using-2-mobos/#findComment-7412032
Yes, then you could transfer the files to a separate pc to render them.
"The Rusher" - Motherboard: Asus Z97-Pro WiFi AC CPU: Intel i7 4790K @ 4.4 GHz CPU Cooler: Coolermaster Nepton 240m RAM: Gskill TridentX 16gb 2400Mhz GPU: Gigabyte G1 Gaming GTX 1060 6GB OC Edition Storage: Samsung 850 EVO 250gb // WD Blue 1tb PSU: Silverstone Strider Gold 650w Case: Coolermaster CM 690 III Window + NZXT Blue LED's
https://linustechtips.com/topic/563591-using-2-mobos/#findComment-7412035
wouldn't it be possible to reprogram the mobo to act like lan
How do you mean, as a server?
You could also try to install a 10gbit network.
https://linustechtips.com/topic/563591-using-2-mobos/#findComment-7412050
Not sure what you mean, but probably not. But why would you go into such troubles to turn a motherboard into an ethernet card?
~ Specs bellow ~
https://linustechtips.com/topic/563591-using-2-mobos/#findComment-7412056
not to turn the mobo to turn the pcie
As said by multiple people, you just plain can't. PCIE cannot be used for that use.
Edited by Rushfriend
Typo
https://linustechtips.com/topic/563591-using-2-mobos/#findComment-7412073
What you're saying doesn't really make sense :) The PCIe is just a port that connect various devices with the motherboard. One of those devices would be an ethernet card.
~ Specs bellow ~
https://linustechtips.com/topic/563591-using-2-mobos/#findComment-7412075
its just the cost of 2 network cards and the amount of ram that will be needed to act as a buffer
What happened to the Ethernet ports on the motherboards? Also, 16GB RAM should be alrightish.
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/563591-using-2-mobos/#findComment-7412155
16 is the size of the simulations/ renders so it would have to be 32 which is not to bad with ddr3 ddr2 its just the max speed for Ethernet ports would be a bottle neck as its a lot of data back and forth
https://linustechtips.com/topic/563591-using-2-mobos/#findComment-7412181
ok: you cannot work on both cpus at the same time, but they can do seperate things simultaniously (like editing and rendering)
https://linustechtips.com/topic/563591-using-2-mobos/#findComment-7412212
40 minutes ago, norain said:
its just nicer when they act like one cpu sharing the tasks
Instead of going 10GB get some PCIe 4GB fiber cards on ebay. ive seen them as low as $10+shipping each.
Get ones with either 2 or 4 4GB fiber ports, 2 or 4 fiber cables to go in between and then do what Linus did in his "Spoeed up your network" videos.
Use this guide to fix text problems in your postGo here and here for all your power supply needs
New Build Currently Under Construction! See here!!!! ----->
Deathwatch:[CPU I7 4790K @ 4.5GHz][RAM TEAM VULCAN 16 GB 1600][MB ASRock Z97 Anniversary][GPU XFX Radeon RX 480 8GB][STORAGE 250GB SAMSUNG EVO SSD Samsung 2TB HDD 2TB WD External Drive][COOLER Cooler Master Hyper 212 Evo][PSU Cooler Master 650M][Case Thermaltake Core V31]
Cupid:[CPU Core 2 Duo E8600 3.33GHz][RAM 3 GB DDR2][750GB Samsung 2.5" HDD/HDD Seagate 80GB SATA/Samsung 80GB IDE/WD 325GB IDE][MB Acer M1641][CASE Antec][[PSU Altec 425 Watt][GPU Radeon HD 4890 1GB][TP-Link 54MBps Wireless Card]
Carlile: [CPU 2x Pentium 3 1.4GHz][MB ASUS TR-DLS][RAM 2x 512MB DDR ECC Registered][GPU Nvidia TNT2 Pro][PSU Enermax][HDD 1 IDE 160GB, 4 SCSI 70GB][RAID CARD Dell Perc 3]
Zeonnight [CPU AMD Athlon x2 4400][GPU Sapphire Radeon 4650 1GB][RAM 2GB DDR2]
Server [CPU 2x Xeon L5630][PSU Dell Poweredge 850w][HDD 1 SATA 160GB, 3 SAS 146GB][RAID CARD Dell Perc 6i]
Kero [CPU Pentium 1 133Mhz] [GPU Cirrus Logic LCD 1MB Graphics Controller] [Ram 48MB ][HDD 1.4GB Hitachi IDE]
Mining Rig: [CPU Athlon 64 X2 4400+][GPUS 9 RX 560s, 2 RX 570][HDD 160GB something][RAM 8GBs DDR3][PSUs 1 Thermaltake 700w, 2 Delta 900w 120v Server modded]
RAINBOWS!!!
 QUOTE ME SO I CAN SEE YOUR REPLYS!!!!
https://linustechtips.com/topic/563591-using-2-mobos/#findComment-7412410
