Adding a Switch to my Home Network
Solved by Oshino Shinobu,
Connect your router to the modem, then the switch to the router. While it could work with modem > switch > router, it doesn't really make sense to use it like that, as data would be in your local network before passing through the router's firewall.
Just getting an 8 Port, Unmanaged Gigabit switch will give you 1000BASE-T (1Gigabit speeds) across the wired local network. Whether that is an improvement over your current setup depends on the speeds your router's wired connections support. If the router you have uses 1000BASE-T LAN interfaces, then getting a switch won't really improve your local wired speeds at all, though it does give you more room to expand and connect devices with wires.
