Literally have been looking online for USB 3.0 drives for about an hour for a good quality one. Every single one above 32GB has negative reviews about high temps, mechanisms not working, and all these other problems about it dying in a month. Are flash drives like OCing a CPU as in you don't know what you're going to get? Or are there actual quality ones that I haven't seen yet.
https://linustechtips.com/topic/563502-best-usb-drive/
There are actual quality ones (where have you been looking?)
I do know that a lot of electronics stores have been doing cheap 16GB and 32GB USB 3.0 drives.
And seriously, if you need USB 3.0, get an external HDD. Use USB 2.0 for drives right now, the speed is just fine.
2017 Gaming PC
Excellent value machine, keeps me going.
CPU: Intel Core i5-6600K | GPU: Nvidia GeForce GTX 1080 8GB | RAM: 16GB DDR4 | Motherboard: MSI Z170A XPOWER GAMING TITANIUM
PSU: Casecom 600W PSU | Case: Corsair Graphite 230T | SSD: Samsung 850 EVO 250GB | HDD: 3TB WD Blue
Dell XPS 15 9560
Beautiful laptop, in a stunning form factor.
CPU: Intel Core i7-7700HQ | GPU: Intel HD Graphics 630/Nvidia GeForce GTX 1050 (not mobile, full GPU) | RAM: 16GB DDR4 | SSD: 512GB SK Hynix SSD
Display: 4K IPS 100% Adobe RGB Touch Panel | I/O: Two USB 3.0 with PowerShare, HDMI, 3.5mm Headphone Jack, SD Card Slot, and Thunderbolt 3 USB-C
Samsung Galaxy S8 64GB | Samsung Galaxy Tab S2 9.7 32GB
https://linustechtips.com/topic/563502-best-usb-drive/#findComment-7410999
Sandisk USB drives are build for fast transfer rates
I got a box load of them
SD cards and USB 3.0 Ultra series
In fact I got the 256GB version of the Ultra USB 3.0
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/563502-best-usb-drive/#findComment-7411073
