Can I have some help with this build please?
My budget is around £1000 including Windows.
I dont want to use microsoftswap to purchase my windows licence
The build will be used for high intensity gaming on two monitors at first and later three. Atleast 1080p.
http://uk.pcpartpicker.com/p/L28pqs
Thanks
https://linustechtips.com/topic/563321-first-pc-build/
Thanks
That build is great! It might even do 1440p on some games.
i like linux
https://linustechtips.com/topic/563321-first-pc-build/#findComment-7408661
14 minutes ago, Y_Chris_Y said:
This PC will also be used for creating animations aswell as rendering them afterwards. I will be using blender, maya and adobe after effects if that helps at all. Thanks
I´d go with the 1231v3 over the 6600k then. The extra threads will help you out in those cases.
https://linustechtips.com/topic/563321-first-pc-build/#findComment-7408705
If you can switch to a Sapphire R9 390. It has a better cooler.
https://linustechtips.com/topic/563321-first-pc-build/#findComment-7408729
