This is my build:
PCPartPicker part list: http://pcpartpicker.com/p/4TWNf7
Price breakdown by merchant: http://pcpartpicker.com/p/4TWNf7/by_merchant/
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($174.89 @ OutletPC)
Motherboard: MSI H97 PC MATE ATX LGA1150 Motherboard  ($86.88 @ OutletPC)
Memory: Kingston HyperX Fury Black 8GB (2 x 4GB) DDR3-1600 Memory  ($34.99 @ SuperBiiz)
Storage: Western Digital BLACK SERIES 2TB 3.5" 7200RPM Internal Hard Drive  ($119.99 @ SuperBiiz)
Video Card: EVGA GeForce GTX 750 Ti 2GB Superclocked ACX Video Card  ($159.79 @ Amazon)
Case: Deepcool KENDOMEN Black ATX Mid Tower Case  ($57.98 @ Newegg)
Total: $634.52
I need help with my PSU since a lot of people told me that the EVGA NEX 750B is really bad.
Please, take as reference this webpage for choosing the PSU ( I'm not from US)
http://www.impacto.com.pe/web/index.php/index/accion/33produ_catego
Thanks in advance
https://linustechtips.com/topic/562842-help-with-psu/
2 minutes ago, Drakomon322 said:
This is my build:
Total: $634.52
Thanks in advance
May I ask what you're doing with this PC? If you're playing games then you can do much better than this. I'd suggest an i3 an R9 380 if that's within your budget or maybe downgrading to a Core i3 to put an SSD in there.
What is the budget for this PSU (in your currency)?
https://linustechtips.com/topic/562842-help-with-psu/#findComment-7400762
This PC is for gaming , programming and web browsing.
My budget for PSU is 80 USD.
https://linustechtips.com/topic/562842-help-with-psu/#findComment-7400777
If you're gaming then I'm going to redo your system. Hold on just a second as I write up a new PC Part Picker link.
https://linustechtips.com/topic/562842-help-with-psu/#findComment-7400794
Just now, Drakomon322 said:
Just help me with PSU, please.
If this system isn't built yet then you can do far, far better.
https://linustechtips.com/topic/562842-help-with-psu/#findComment-7400807
The EVGA GTX 750 TI FTW 2GB is more than enough for the games that I'm gonna play.
Well, look at it this way, do you want better or good enough?
BOINC Setup:
i5 7200U @ Stock
Core2Duo T6600 @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
https://linustechtips.com/topic/562842-help-with-psu/#findComment-7400810
The games that I'm gonna play are Dota 2, Hearhtstone , CS GO , SC2 and Overwatch.
I think EVGA GTX 750 TI FTW 2GB is more than enough.
Ok then, we can 1. Make it cheaper 2. Make them all play better for the same price
BOINC Setup:
i5 7200U @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
https://linustechtips.com/topic/562842-help-with-psu/#findComment-7400822
OK, then a Core i3 4170 is good enough too unless you're doing heavy graphical works with the CPU. An SSD would help you out dramatically however.
https://linustechtips.com/topic/562842-help-with-psu/#findComment-7400823
I'll play in 19'' 1080p Samsung monitor.
I think I5 4460 is pretty good for programming, gaming and web browsing.
https://linustechtips.com/topic/562842-help-with-psu/#findComment-7400835
As I said, an i5 is overkill for what you're doing unless you're doing high-tier programming (programming games and stuff). I'm trying to help you save money so you can spend it properly.  Yes, it will have no trouble doing all those things, but why spend more money on something you don't need?
Here's my suggestion.
CPU: Intel Core i3-4170 3.7GHz Dual-Core Processor  ($114.78 @ OutletPC)
Storage: A-Data Premier SP550 120GB 2.5" Solid State Drive  ($38.99 @ Amazon)
Storage: Hitachi Deskstar 7K2000 2TB 3.5" 7200RPM Internal Hard Drive  ($59.95 @ Amazon)
Case: NZXT Source 220 ATX Mid Tower Case  ($48.99 @ SuperBiiz)
Power Supply: Corsair CX 430W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($44.99 @ Amazon)
Total: $589.36
Generated by PCPartPicker 2016-03-09 23:36 EST-0500
https://linustechtips.com/topic/562842-help-with-psu/#findComment-7400844
Yes, it is, but for the games you want to play, that i3 will do fine as well
BOINC Setup:
i5 7200U @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
https://linustechtips.com/topic/562842-help-with-psu/#findComment-7400847
Total: $589.36
I'm majoring in Computer Science.
I'm gonna stick with i5 4460.
I just need help with the PSU.
As I said above. take as reference this web page
https://linustechtips.com/topic/562842-help-with-psu/#findComment-7400857
This will do http://www.impacto.com.pe/web/index.php/index/accion/3778detal_produc
As I said, an i5 is just a waste of money for you unless your computer science major will involve programming CPU heavy applications. I use an i3 4360, one of the best i3s, and have absolutely no problems running GTA with a correctly paired graphics card, no problems running multiple SFML windows or running a single VM on this CPU.
Anyways, that PSU will do.
https://linustechtips.com/topic/562842-help-with-psu/#findComment-7400874
