Hello guys,
I have this issue, i have Intel® Core™2 Extreme Processor QX6700
(8M Cache, 2.66 GHz, 8 GB ram, Corsair 240gb SSD and GPU ASUS GTX 760 and my CPU goes 95+ while playing battlefield 3, and i have nothing running in the background and i have even razer game booster on, i just cant figure out whats taking so much load from my CPU while running BF3, my average CPU load is about 88%-100% which is crazy...
can some tell me how the hell i can fix this issue cause 93%+ cpu load starts affecting my fps and that's freaking annoying.
any help would be greatly appreciated.
thanks
also i should mention my cpu load on idle not gaming goes about 0%-4% i also own after market Zalman CPU cooler and it seems to be working just fine.
https://linustechtips.com/topic/56281-cpu-load-93-100-while-playing-bf3/
While that does seem very high, Battlefield is a CPU intensive game. It always has been
I am good at computer
Motherboard: Gigabyte G1 sniper 3 | CPU: Intel 3770k @5.1Ghz | RAM: 32Gb G.Skill Ripjaws X @1600Mhz | Graphics card: EVGA 980 Ti SC | HDD: Seagate barracuda 3298534883327.74B + Samsung OEM 5400rpm drive + Seatgate barracude 2TB | PSU: Cougar CMX 1200w | CPU cooler: Custom loop
I just randomly about 2 ish months ago started getting 80-100% cpu usage my my 4.3Ghz 3570k, I went through everything to try and fix it and even talked to EA support but they don't even know what a cpu is so that didn't help much. I never could figure out a fix for it.
Are you saying this is normal? to run a game on CPU 100% load, do you think replacing my CPU cooler with an internal water cooling system will help in anyway if i manage to decrease the CPU temp a bit? while gaming my CPU temp goes about as high as around 88c
please advise
please advise
Increasing your cooling capabilities won't help in this case as your CPU isn't getting temperature throttled. It isn't normal, but it is not uncommon with battlefield especially on a core2 CPU. If you increase your cooling then you can overclock a bit which could reduce load. Otherwise just leave it
Get a new cpu and mobo, you have a 760 so you may as well bring the rest of your rig up-to-date...
PC: Corsair C70 Arctic, FX 9370, Corsair H80i, Gigabyte 990fxa-ud3, Corsair Vengence 16gb, Palit JetStream GTX 970, OCZ Vertex 4 128gb and Western Digital Blue 1Tb + 500gb, Antec Gamer 520w
Peripherals: Logitech G19 and SteelSeries Sensei RAW
Toshiba L50-A: i7 4700mq, 8gb, 1TB HDD, GT 740M 2gb
Thanks mate, i hope my CPU wont die cause of this 100% load while gaming
That's perfectly normal, if anything its a good thing. Why buy a nice CPU if it isn't getting used? I used to have an old E7600 core 2 duo that maxed itself on everything, in a way it made me happy because I felt like I was getting the most out of it, obviously later I had to upgrade but still don't be surprised if your CPU is at 100%.
It is normal, as a video editor myself I frequently get my CPU up to 100% and there is nothing bad about it. Your system has no faults.
Hello guys,
thanks
In a word performance..........His CPU is straining to keep up with his GPU, which is not a good thing......
A core2 and gtx760 is a big bottleneck....
----Ryzen R9 5900X----X570 Aorus elite----Vetroo V5----240GB Kingston HyperX 3k----Samsung 250GB EVO840----512GB Kingston Nvme----3TB Seagate----4TB Western Digital Green----8TB Seagate----32GB Patriot Viper 4 3200Mhz CL 16 ----Power Color Red dragon 5700XT----Fractal Design R4 Black Pearl ----Corsair RM850w----
I don't think that's true cause I had the same issue back when I used to run asus gtx 295 gpu which is like 5 years older than the gtx 760.
Overclock. I had Q6600 before upgrade and with low-med I hit constantly over 80% usage. Now with med-high setting I don't get over 60% (4770K). If you want smoother experience, lower graphics and play on smaller servers.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
It is the cause, Battlefield 3 is CPU intensive, a core2 doesn't cut it anymore, Even high end machines get chugged out on battlefield 3 on 64 player maps.
I just lowered from Ultra settings to medium and it helped by around 5%-10% on the cpu load..
thanks guys
If you got that cpu at stock speeds then its pretty normal to get that high cpu usage in bf3 (esp on 64 player maps) ,my q9550,when at stock speeds (2,83 ghz) was doing 90-100 % cpu usage pretty much nonstop on 64 player maps.
Like LoGiCalDrm said,you can also overclock your cpu (pretty easy with the cpu you got)  to get more fps
I will try that, i have the XFX Nforce 680i mobo, i still dont know if i can overclock it from the bios it's a pretty old board..
That is an extremely old CPU, it would be a much better value to just buy a newer one with a cheap cooler than to purchase an expensive liquid cooler, especially if your motherboard doesn't support overclocking. I have a 2500k at 4.8ghz and it is pretty much always at 100% when playing battlefield that just means battlefield is good at utilizing resources.
2500k @ 4.8, R9 290x, 256GB Vertex 4, Filco Majestouch 2 Tenkeyless Brown, Logitech G602 Mouse, Kingwin Lazer 1000w Platinum PSU, Corsair Dominator Platinum RAM 8GB @1866, Asrock Extreme 3 Gen 3, Xonar U7, Sennheiser 598, Switch 810, Coolermaster Hyper 212 with 1x Noctua nf-f12
My Intel Core i3-2120 runs at around 70-80% playing BF3, I'd like to say it's normal but I'm really not sure.
DESKTOP - Motherboard - Gigabyte GA-Z77X-D3H Processor - Intel Core i5-2500K @ Stock 1.135v Cooling - Cooler Master Hyper TX3 RAM - Kingston Hyper-X Fury White 4x4GB DDR3-1866 Graphics Card - MSI GeForce GTX 780 Lightning PSU - Seasonic M12II EVO Edition 850w  HDD -  WD Caviar  Blue 500GB (Boot Drive)  /  WD Scorpio Black 750GB (Games Storage) / WD Green 2TB (Main Storage) Case - Cooler Master 335U Elite OS - Microsoft Windows 7 Ultimate
