you're way overpaying on cool-looking RAM.
get something cheaper
Snorlax: i7 5820k @4.5ghz, Asus X99 Pro, 32gb Corsair Vengeance LPX 2666, Cryorig R1 Ultimate, Samsung 850 evo 500gb, Asus GTX 1080 ROG Strix, Corsair RM850x, NZXT H440, Hue+
Smallsnor: Huawei Matebook X
Canon AE-1 w/ 50mm f/1.8 lens
Pentax KM w/ 55mm f/1.8 SMC lens
Zenit-E w/ 58mm f/2 Helios lens
Panasonic G7 with 14-42mm f/3.5 lens
Polaroid Spectra System
https://linustechtips.com/topic/562403-first-pc-build-help/#findComment-7395757
You can get a better CPU cooling solution, such as an AIO Liquid Cooler, or a beefier GPU if you buy your Windows licence through reddit microsoftswap for as low as $10. You could also get the Windows 10 beta and get upgraded for free to a full windows 10 licence.
NCASE M1 i5-12600kf  RTX 4060Ti FE Z690M-ITX  SF600 NH-L9x65 Chromax  LPX 32GB
https://linustechtips.com/topic/562403-first-pc-build-help/#findComment-7395773
Just now, Y_Chris_Y said:
High intensity games. I will be starting with a dual screen set up and later be upgrading to a triple screen set up. 1080p at lowest
Ok, thank you for the information. I cannot help further, for I have to go to school, but I hope someone else can help based on this info.
I Eat, Therefore I Am
https://linustechtips.com/topic/562403-first-pc-build-help/#findComment-7395775
14 minutes ago, Y_Chris_Y said:
Can I have some help improving this build please?
http://uk.pcpartpicker.com/p/RfKvHx
My budget is around £1000 including Windows
Thanks
I would get this instead:
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  (£199.99 @ Amazon UK)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  (£26.99 @ Novatech)
Motherboard: Gigabyte GA-Z170XP-SLI ATX LGA1151 Motherboard  (£108.99 @ Amazon UK)
Memory: Kingston HyperX Fury Black 16GB (2 x 8GB) DDR4-2133 Memory  (£59.20 @ Novatech)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  (£64.80 @ Amazon UK)
Storage: Western Digital BLACK SERIES 1TB 3.5" 7200RPM Internal Hard Drive  (£63.38 @ Amazon UK)
Video Card: MSI Radeon R9 390 8GB Video Card  (£269.99 @ Amazon UK)
Case: NZXT S340 (Black) ATX Mid Tower Case  (£58.14 @ Amazon UK)
Power Supply: EVGA SuperNOVA G2 650W 80+ Gold Certified Fully-Modular ATX Power Supply  (£74.99 @ Amazon UK)
Operating System: Microsoft Windows 10 Home OEM (64-bit)  (£78.98 @ Novatech)
Wireless Network Adapter: Gigabyte GC-WB867D-I 802.11a/b/g/n/ac PCI-Express x1 Wi-Fi Adapter  (£31.50 @ Amazon UK)
Total: £1036.95
Generated by PCPartPicker 2016-03-09 13:44 GMT+0000
CPU  i7-6700k @ 4.8 GHz  GPU Gigabyte GTX 980 Ti G1 Gaming 6GB Motherboard ASUS MAXMIMUS VIII RANGER  Case Phanteks Enthoo Evolv ATX  RAM 4 x 8GB HyperX Fury 32GB 2400 MHz  Cooling Corsair H110i PSU Be Quiet! Power Zone 1000W
https://linustechtips.com/topic/562403-first-pc-build-help/#findComment-7395801
8 minutes ago, Y_Chris_Y said:
Red and black but the colour scheme is less important than the build. If i can get better parts for the same price but it ruins the colour scheme, i dont care.
Here:
PCPartPicker part list: http://uk.pcpartpicker.com/p/2LCHkL
Price breakdown by merchant: http://uk.pcpartpicker.com/p/2LCHkL/by_merchant/
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler  (£26.49 @ Ebuyer)
Motherboard: MSI Z170A PC MATE ATX LGA1151 Motherboard  (£93.67 @ Amazon UK)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2133 Memory  (£63.99 @ Amazon UK)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  (£37.98 @ Novatech)
Power Supply: EVGA 750W 80+ Gold Certified Semi-Modular ATX Power Supply  (£76.99 @ Novatech)
Total: £1002.52
Generated by PCPartPicker 2016-03-09 13:49 GMT+0000
Good parts, plus your color scheme.
https://linustechtips.com/topic/562403-first-pc-build-help/#findComment-7395816
Cheaper and better:
Motherboard: ASRock Z170M Pro4S Micro ATX LGA1151 Motherboard  (£78.45 @ Amazon UK)
Memory: Kingston FURY 16GB (2 x 8GB) DDR4-2400 Memory  (£60.50 @ More Computers)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (£41.86 @ Amazon UK)
Total: £986.19
Generated by PCPartPicker 2016-03-09 13:52 GMT+0000
https://linustechtips.com/topic/562403-first-pc-build-help/#findComment-7395830
