I built my pc a little less than 1 month ago and have had little to no problems... Until now.  I mainly have been playing fallout 4 and using microsoft office for school, and id get the occasional fallout 4 crash, but nothing like an amazingly high amount, maybe 3 times in almost a month.  TODAY I have had my PC/Fallout crash 5-10 times.  I was using it for school earlier(about 2 hours) and it was fine. My specs are listed on my profile, but the main things are i3 6100/8gb ram/amd 380x and I run Fo4 on ultra with framerates of 40-60+ depending on locations.
THE TWO MAIN CRASHES I HAVE GOTTEN are the game crashing and the mouse only show up in the taskbar, i can press start and shut down from there, and the other crash is my monitor going blank and saying that there is no signal.  the first one I just restart my pc, but for the second type of crash I have unplugged my hdmi cable, then repugged it in, turned my monitor off, and turned it onn again, Ive even waited over an hour to see if that would fix it, there are no updates that need to be applied, and no debug lights on my MOBO, if there is anything else you need please comment
CPU - Intel I3-6100 Motherboard - MSI Z170-A PRO RAM G.SKILL NT Series 8gb 2400MZ DDR4 GPU - Power Color R9 380X Case - NZXT Source 220 Window Storage - 1TB Western Digital Blue PSU - Corsair CX500 OS - Windows 10 Pro
https://linustechtips.com/topic/562162-pcfallout-keeps-crashing-need-help/
download DDU, then re install drivers.
CPU: me | Dark Rock Pro 3 | Asus Z170-A | 32GB Dominator Plats | 512gb SSD/4TB WD Black | 980Ti | BQ Silent Base 800 | EVGA 850w |
01101110 01101111 00100000 01101111 01101110 01100101 00100000 01101100 01101111 01110110 01100101 01110011 00100000 01111001 01101111 01110101
BEST PC FOR THE PRICE:
$400 $500 $600 $700 $800 $900 $1000
If you want to Silence your PC/Room more, contact me.
NOTE I am getting IN GAME sound through my headset which is plugged into my pc when the screen goes blank during the second type of crash!
DDU?
20 hours ago, i7-6700K said:
none of the links are working, I tried last night and again today but I can't get them to work
Just search up DDU on google. it should be the first link.
No, the link that you posted works, but the download links arn't working
how is it not working?
I went on a different site and the download worked, but the links to download the program would not download it, even when I clicked the extra link for if the download didnt automatically start
i went on the website and i couldnt download it either. Just wait, maybe the servers are down. IF you're impatient then just manually un-install the drivers.
I said I used a different site
