Lian-Li LQ Help
Solved by Deli,
If you only mount a 240mm rad on the right side. That won't be enough rad space to cool one CPU and two GPUs.
If you mount 240mm rad on both sides, the left rad and fans will block the second graphic card.
The rear exhaust can mount a 120mm rad, but the right side rad must be 35mm or thinner. Even if you manage to mount a 240 rad on the right side and a 120mm on the rear. That'll still not enough for a Haswell-E CPU and two Titan-Xs. 480mm rad space is the minimum for that set up.
