Hows it going everyone. I had an urgent question about building pc. I looked up a computer that I was trying to build. But finds out the graphics card that was originally about 150 dollars is much higher now! I was wondering if someone could help me choose a graphics card does the about the same at a lower price? https://pcpartpicker.com/user/MrPerezOP/saved/#view=ygcwrH Here should be the full build. Thanks again!
https://linustechtips.com/topic/561893-choosing-graphics-card-help/
Are you able to save up some more? I wouldn't go with an i3, and you don't have an SSD. I would get these before getting into the GPU.
CPU: AMD 5950X    MB: Asus ROG Crosshair VIII Dark Hero    RAM: HyperX Predator 64GB    GPU: Nvidia RTX 3090 Ti FE    SSD: Seagate FireCuda 530 2TB
PSU: EVGA 1200w P2    COOLING: EK AIO Elite 360    CASE: Fractal Design Torrent
   DISPLAY: LG CX48 4k OLED    AUDIO: HIFIMAN Arya SE
whats your full budget? Like for the whole PC
Main PC |CPU - i7-6700k|GPU - R9 290x tri-x 4gb|RAM - 16gb ddr4|MOBO - MSI z170 - A PRO|HDD - WD 1TB/240gb Sandisk |PSU - 700w Raidmax
Laptop |CPU - i7 4720hq|GPU - 960m 2gb|Ram - 8gb 2x4|Model - y50-70 Touch|SSD - 240gb Patriot drive|Display - 1920x1080 IPS touch
The computer if for a first time gamer I'm trying to go crazy. Some nice to get him started.
I assume you mean "not trying to go crazy" because there isn't anything crazy about that build lol.
Sometimes spending too little is worse than just buying a console. Also you don't want to shoot for the cheapest parts you can find. Go with trusted name brands or you'll have nothing but problems. Not something a first-time PC builder will want. If they can't afford that, then they simply are not ready for it yet.
