Reinstalling Windows 10 on my brother new computer because it is currently 32bit and he needs 64bit. My question is when I go to make the USB drive to boot from it gives me an option between "Windows 10,  Window 10 Home single Language, and Windows 10 N".  On his computer he is using the Windows 10 Home so not sure if I am suppose to get the single language or just the window 10.
https://linustechtips.com/topic/561780-upgrading-between-32-and-64bit/
Just get option two between Windows 10 & Windows 10 Pro..
        - AMD Ryzen™ 5 1400 Processor
        - Asus Prime A320M-K ATX motherboard
        - Zotac GTX 1050Ti 4GB OC Edition
        - Kingston 8GB DDR4 2133Mhz Ram
        - Corsair VS 550 power supply
        - Kingston A400 240GB SSD
                                                       - 1TB WD BLUE HDD Hard Disk & Samsung 320GB HDD(7200RPM)
        - CPU COOLER: Stock Cooler(AMD)
For Win10 they use the same installer for both options, and your license key tells it which version to install. Just do the regular Windows 10 installer.
END OF LINE
-- Project Deep Freeze Build Log --
Quote me so that I always know when you reply, feel free to snip if the quote is long. May your FPS be high and your temperatures low.
