As my school has ended and I am going to college in a couple of months I wanted a workhorse that can easily do my jobs. After researching quite a bit I decided to build an itx rig that is small enough to be easily movable (During vacations when I visit my home) and which takes less space. For other small uses like taking notes or consuming media on the go I will be buying a cheap chromebook.
Please give me suggestions to improve it/build something similar while spending less. Also, will the cpu cooler that I have chosen fit inside the case?
The "build"
CPU: *Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($374.88 @ OutletPC)
CPU Cooler: *Corsair H75 54.0 CFM Liquid CPU Cooler  ($74.64 @ Amazon)
Motherboard: *MSI Z170I GAMING PRO AC Mini ITX LGA1151 Motherboard  ($172.16 @ Amazon)
Memory: *G.Skill Ripjaws V Series 32GB (2 x 16GB) DDR4-3200 Memory  ($213.52 @ Amazon)
Storage: *Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($86.75 @ OutletPC)
Storage: *Western Digital BLACK SERIES 1TB 3.5" 7200RPM Internal Hard Drive  ($73.89 @ OutletPC)
Case: *Fractal Design Node 304 Mini ITX Tower Case  ($59.99 @ Newegg)
Power Supply: *SeaSonic 750W 80+ Gold Certified ATX Power Supply  ($115.98 @ Newegg)
Monitor: AOC i2369V 60Hz 23.0" Monitor  ($159.99 @ B&H)
Mouse: Mionix Castor Wired Optical Mouse  ($69.99 @ Amazon)
Headphones: Sennheiser HD 439 Headphones
Total: $1488.54
Generated by PCPartPicker 2016-03-07 08:16 EST-0500
Please note that I already have the PSU and the Headphones. This build is gonna cost me around 1,13,559 INR(1,696 USD). Most components I am purchasing are from NewEgg India with Processor and Cooler coming from Amazon India.
Also, give suggestions about a nice Mechanical Keyboard.
https://linustechtips.com/topic/561156-mini-itx-build/
I wouldn't really recommend the Node 304. Sure it's mITX, but it's really big. The actual footprint is not much smaller than a regular ATX tower, it's just a lot shorter. I'd take a look at the Silverstone SG13, I have one and I love the case. I also have a couple of SG05s (the predecessor to the SG13) and those were awesome too, Silverstone in general makes great SFF cases. Also, no GPU? And you don't need more than 16GB of RAM, and it would be better to get a single 500GB SSD. I have the 850 EVO 500GB and it's hella fast. And the HDD is pretty overpriced for what it is, better to go with a Seagate Barracuda or WD Blue.
https://linustechtips.com/topic/561156-mini-itx-build/#findComment-7382542
Will the SG13 be able to fit everything without much hassle? Also, I am currently waiting for new cards to be released as by then I will have enough money for the highest end graphics card and they will offer better performance too.
https://linustechtips.com/topic/561156-mini-itx-build/#findComment-7382548
In case of RAM I am going with 32 because I will need it to do some video editing and run some other demanding applications but mainly video editing and gaming. only. And my plan for the the two SSDs was to put them in raid 0 and enjoy some helluva performance. Also, thnx for reminding me of the barracuda that one had slipped my mind. :P
https://linustechtips.com/topic/561156-mini-itx-build/#findComment-7382678
Just now, ThatNewb said:
In case of RAM I am going with 32 because I will need it to do some video editing and run some other demanding applications but mainly video editing and gaming. only. And my plan for the the two SSDs was to put them in raid 0 and enjoy some helluva performance. Also, thnx for reminding me of the barracuda that one had slipped my mind :P
Well if you have power loss you can destroy the RAID so it's kind of risky. And you have no GPU btw.
https://linustechtips.com/topic/561156-mini-itx-build/#findComment-7382687
Not a bad build.  I would consider a different case though.  Something that looks prettier while you're at it.  No need to watercool unless you plan on overclocking like crazy.  Also, why not try a samsung 950 pro m.2 instead?  It'll cost a bit more if you still want 500gb, but that would be helluva performance.  If you're doing video editing why not get a slightly larger/nicer monitor too.  For keyboards, i have the razer deathstalker which is pretty good but i got a really good deal on it ($50 usd with a razr abyssus).  My friend has the logitech G910 which is one sweet keyboard.  I would've loved to get that one, but it was just a bit out of my price range and he got an awesome deal on it ($110)
CPU: AMD FX-6100 3.3GHz 6-Core OEM/Tray Processor + Antec Kuhler H2O 620 Liquid CPU Cooler
Motherboard: Asus Sabertooth 990FX ATX AM3+ Motherboard Memory: G.Skill Ripjaws X Series 16GB (4 x 4GB) DDR3-1866 Memory
Storage: Kingston HyperX 3K 120GB 2.5" Solid State Drive + Western Digital Caviar Green 500GB 3.5" 5400RPM Internal Hard Drive & Seagate Barracuda 750GB 3.5" 7200RPM Internal Hard Drive
Video Card: MSI GeForce GTX 960 2GB Video Card Case: Rosewill THOR V2 ATX Full Tower Case + Thermaltake TR2 750W 80+ Bronze Certified Semi-Modular ATX Power Supply
Wireless Network Adapter: TP-Link TL-WDN4800 802.11a/b/g/n PCI-Express x1 Wi-Fi Adapter Monitor: Asus VK278Q 27.0" Monitor
Peripherals: Razer DeathStalker Wired Gaming Keyboard + Razer Abyssus Wired Optical Mouse Headphones: Bose SIE2i Orange Earbud Headphones + Mic: Kaxidy Stereo MIC
https://linustechtips.com/topic/561156-mini-itx-build/#findComment-7382919
how about this?
CPU Cooler: Corsair H75 54.0 CFM Liquid CPU Cooler  ($74.64 @ Amazon)
Motherboard: Gigabyte GA-Z170N-WIFI Mini ITX LGA1151 Motherboard  ($134.99 @ B&H)
Memory: *G.Skill Ripjaws V Series 32GB (2 x 16GB) DDR4-3200 Memory  ($242.40 @ Amazon)
Storage: Samsung 950 PRO 512GB M.2-2280 Solid State Drive  ($325.99 @ SuperBiiz)
Storage: Western Digital WD Blue 1TB 2.5" 5400RPM Internal Hard Drive  ($59.99 @ SuperBiiz)
Case: Thermaltake Core X1 Mini ITX Tower Case  ($64.99 @ Amazon)
Power Supply: SeaSonic 750W 80+ Gold Certified ATX Power Supply  (Purchased For $0.00)
Monitor: AOC e2752Vh 60Hz 27.0" Monitor  ($129.99 @ Best Buy)
Keyboard: Logitech G910 Orion Spark Wired Gaming Keyboard  ($139.99 @ Amazon)
Headphones: Sennheiser HD 439 Headphones  (Purchased For $0.00)
Total: $1617.85
Generated by PCPartPicker 2016-03-07 10:13 EST-0500
https://linustechtips.com/topic/561156-mini-itx-build/#findComment-7383012
31 minutes ago, ShaunC said:
how about this?
Total: $1617.85
This case is a bit too large for my purposes so I will pass. Buying the 950 pro will jack my budget up by 20K and I can't afford it. :(  I will definitely consider that monitor! And thnx for the keyboard recommendation!
https://linustechtips.com/topic/561156-mini-itx-build/#findComment-7383166
24 minutes ago, ThatNewb said:
I looked up the monitor but couldn't find what panel it used. Can you tell me if you know?
I cannot find what panel it uses either. sorry!
https://linustechtips.com/topic/561156-mini-itx-build/#findComment-7383331
