Check out the Phanteks P400(s) and Evolve if you don't like the look of the Enthoo but basically it make 0 difference as long as you have some air in and some air out. go for looks / features you want.
Phanteks is hard to beat on price-quality at the mo.
I don'T PreSS caPs.. I juST Hit THe keYboARd so HarD iT CriTs :P
Quote or @dzzope to get my attention..
airflow and silence are opposites in this situation. I was going to say the Corsair air 540 has best airflow, cable management and functionality, but as it has lots of airflow it isn't the quietest case. If you want quiet you are going to sacrifice airflow.
1 hour ago, Sid Manly said:
Those are good reviews but I don't like the look of them.
I would like something with silence.
What about the Corsair 330R Titanium edition?
If you want high airflow AND silence, the only option is to control the moving parts in the case.  I find it funny that you pick the 330R instead of the Phanteks Enthoo Pro, which comes with a six fan hub controller to keep things quiet.
The Pro M does not come with the fan hub controller, but the Acrylic version does:  http://pcpartpicker.com/part/phanteks-case-phes515pabk
