CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor  ($199.89 @ OutletPC)
Motherboard: Gigabyte GA-H170M-DS3H Micro ATX LGA1151 Motherboard  ($83.99 @ SuperBiiz)
Memory: Corsair Vengeance LPX 8GB (1 x 8GB) DDR4-2400 Memory  ($29.99 @ Newegg)
Storage: A-Data Premier SP550 120GB 2.5" Solid State Drive  ($38.99 @ Amazon)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($46.89 @ OutletPC)
Video Card: XFX Radeon R9 390 8GB Double Dissipation Video Card  ($318.98 @ Newegg)
Case: Fractal Design Core 1000 USB 3.0 MicroATX Mid Tower Case  ($29.99 @ Newegg)
Power Supply: SeaSonic S12II 520W 80+ Bronze Certified ATX Power Supply  ($55.99 @ SuperBiiz)
Monitor: Asus VS239H-P 23.0" Monitor  ($134.89 @ Amazon)
Keyboard: Cooler Master Storm QuickFire Rapid Wired Gaming Keyboard  ($69.99 @ Amazon)
Total: $1009.59
Generated by PCPartPicker 2016-03-06 17:06 EST-0500
i5-4690k@4.5GHz || MSI GTX 970 || MSI z97 Gaming 5 || NZXT Kraken x61 || WD Black 1TB || Crucial MX100 || 8GB Corsair Vengeance Pro || Corsair RM750 || NZXT H440 || Corsair k70 RGB mx browns || Acer H236HL || ViewSonic VX2255wm-4
https://linustechtips.com/topic/560822-computer-build-help/#findComment-7378887
30 minutes ago, DyroZang said:
@Amazingasian Thank you so much..
Do you need Windows?
Oops, no RAM...1 sec...
$1004:
CPU: Intel Core i5-6500 3.2GHz Quad-Core OEM/Tray Processor  ($189.49 @ SuperBiiz)
CPU Cooler: Deepcool GAMMAXX 300 55.5 CFM CPU Cooler  ($19.99 @ Newegg)
Motherboard: Gigabyte GA-H110M-A Micro ATX LGA1151 Motherboard  ($49.99 @ Amazon)
Memory: G.Skill NT Series 8GB (1 x 8GB) DDR4-2133 Memory  ($30.99 @ Newegg)
Storage: A-Data Premier SP550 240GB 2.5" Solid State Drive  ($59.99 @ Amazon)
Video Card: Sapphire Radeon R9 390 8GB Nitro Video Card  ($309.99 @ SuperBiiz)
Case: Thermaltake Versa H22 ATX Mid Tower Case  ($34.98 @ Directron)
Power Supply: XFX XT 600W 80+ Bronze Certified ATX Power Supply  ($46.98 @ Newegg)
Operating System: Microsoft Windows 10 Home OEM (64-bit)  ($89.99 @ NCIX US)
Case Fan: Kingwin CF-012LBR 40.0 CFM 120mm  Fan  ($3.98 @ OutletPC)
Monitor: Acer R240HY bidx 60Hz 23.8" Monitor  ($131.99 @ Amazon)
Keyboard: Logitech K120 Wired Standard Keyboard  ($11.99 @ SuperBiiz)
Total: $984.33
Generated by PCPartPicker 2016-03-06 17:36 EST-0500
https://linustechtips.com/topic/560822-computer-build-help/#findComment-7378968
$1004:
Total: $984.33
Yes I need Windows
https://linustechtips.com/topic/560822-computer-build-help/#findComment-7379090
