Power Supply Help
Go to solution Solved by CGurrell,
Ok so your 700W unit is actually dangerous right now, I would recommend not using the PC at all unless it's completely necessary.
with your current config, a good quality unit with a continuous power output of at least 450W is what you need. With this info, check out http://www.tomshardware.co.uk/forum/id-2547993/psu-tier-list.html. It's a great list that separates the good from the mediocre and the downright dangerous. Pick anything Tier 3 and up that can provide 450W or more, then look at the local stores or online stores that deliver to your area, and get cracking
Wanna ask about a question about my PSU it suddenly blows like burnt smell and I immediately turned off my PC and unplug everything and check the inside of my PSU and theres no burnt capacitors or bulge or smell like the one I smell at the back of the fan of the PSU and a few hours later i turn on my PC again and it works fine the blow of the PSU at the back smells normal now and the temp of my other hardwares is normal and my PSU is not actually a "RATED" its just a cheapo "GENERIC 700watts" one (still saving up for a better one) anyway my question is whats the problem of the PSU?
heres my specs:
amd phenom ii x6 1055t
gtx 750ti stormx dual
8gb ram
2 HDD
https://linustechtips.com/topic/560595-power-supply-help/
450 watts will be enough
Main gaming pc: Lian-Li Lancool II Mesh Performance - Ryzen 5 5600X - MSI GTX1080Ti Armor - AMD Wraith Spire RGB - ASUS TUF Gaming B550 Plus - Corsair Vengeance RGB PRO 2x8GB 3200MHz - 500GB M.2 (and a few other drives)
Gaming laptop: ASUS GL552VW: i7 6700HQ - GTX960M 2GB - 8GB DDR4 2166Mhz RAM - 1TB 7200RPM HDD
https://linustechtips.com/topic/560595-power-supply-help/#findComment-7376559
Hi tnx for the answer but it still not the answer i was looking for my question is why did my power supply suddenly smell like burnt thing and it didnt shut my PC off when it happen and when i turn it on again its normal my temps are normal and the burnt smell is gone and i also check inside of the PSU
https://linustechtips.com/topic/560595-power-supply-help/#findComment-7376580
Because you have a low quality PSU without protections and can't stand heavy load (or in your case any load) and will probably die soon. Keep in mind that wattage costs a lot (cheap 700W unit is dangerous!). So if you are on a tight budget, pick a 3-400W unit (you are perfectly safe with 300W), and buy reliability instead of unnecessary wattage.
https://linustechtips.com/topic/560595-power-supply-help/#findComment-7376689
Current System - Intel Core i7-3770k @ 4.5GHz - 16GB Corsair Vengeance DDR3-1600 - Corsair H110i GT - 2x EVGA GTX 970 FTW+ in SLI - XFX Pro Series Black Edition 1250W - Samsung 840 EVO 128GB Boot SSD - WD Green 2TB Mass Storage HDD - Fractal Design Define S Windowed Edition with Green LED Lighting provided by 2 Bitfenix Spectre PRO 140mm fans, and 2 Corsair SP140 Green LED fans - Samsung U28D590D 4K Main Monitor with BenQ GW2265 1080p Side Monitor
https://linustechtips.com/topic/560595-power-supply-help/#findComment-7382153
Hi! thanks for the reply, im gonna check the link :D
https://linustechtips.com/topic/560595-power-supply-help/#findComment-7382871
No problem mate, any more questions just let me know, i'm following this thread so if you reply here I'll get a notification :)
https://linustechtips.com/topic/560595-power-supply-help/#findComment-7382995
