you can get some like the SilverStone SST-EC03B-p to get an internal USB 3.0 header. You can also get a USB 3.0 to 2.0 converter, but you will only get 2.0 speeds
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
https://linustechtips.com/topic/56057-usb3-connection/#findComment-756244
Just change them to usb 2.0 (case should have come with a cable).
This, And I believe there are PCIE cards that can do this but they will look ugly
Main Rig: -FX8150 -32gb Kingston HyperX BLUE -120gb Kingston HyperX SSD -1TB WD Black -ASUS R9 270 DCUII OC -Corsair 300r -Full specs on Profile
Other Devices: -One Plus One 64gb Sandstone Black -Canon T5 -Moto G -Pebble Smartwatch -Nintendo 2DS -G27 Racing Wheel
#PlugYourStuff - 720penis - 1080penis - #KilledMyWife - #LinusButtPlug - #HashtagsAreALifestyle - CAR BOUGHT: 2010 Corolla
https://linustechtips.com/topic/56057-usb3-connection/#findComment-756247
Yes it would. You just have to make sure it comes with an internal header. Not all PCIe USB 3.0 card comes with that
https://linustechtips.com/topic/56057-usb3-connection/#findComment-756255
my case has the cable, i simply plug it into the socket on the pci card dont I?
The internal header on the USB 3.0 cable from your case will plug into the internal connector on the PCIe card
https://linustechtips.com/topic/56057-usb3-connection/#findComment-756271
@Volbet yes so why did you say "you just have to make sure it comes with an internal header. Not all PCIe USB 3.0 card comes with that" ??????
No. Some only comes with the external ports (Like to ones on the front on your case).
https://linustechtips.com/topic/56057-usb3-connection/#findComment-756282
Internal USB 3.0 connector                                                 External USB 3.0 connector (I'm sorry that I couldn't find a better picture)
https://linustechtips.com/topic/56057-usb3-connection/#findComment-756340
