Hi I am going to do my own custom cables for my PC in red, black and white. I do not want to spend the money and get a cable crimper so i am planning on just getting pre-crimped cable. I can find it on places like Mainframe Customs but it is very expensive. Where is the cheapest place to buy some?
https://linustechtips.com/topic/560446-custom-cable/
  • 2 weeks later...
1 minute ago, wkelly said:
I think about 30cm would work for the 24 pin motherboard, 8 pin CPU and 4 pin GPU connector.
8pin or 6pin GPU cables? Cables curved correct? And do you have atx pin remover?
Contact us for a quotation or a chat [Modguru shop] [Facebook] Creating the highest quality products ever
https://linustechtips.com/topic/560446-custom-cable/#findComment-7465516
0.7USD per 30CM wire, same for the shorter to make a curve.
0.7USD per connector.
24pin 30CM = 18,2USD
8pin EPS 30CM = 7USD
6pin GPU 30CM = 5,6USD | x 4 = 22,4USD
Pin remover = 6USD
https://linustechtips.com/topic/560446-custom-cable/#findComment-7465579
