From the build I have listed below, I have a few questions.
1. Can I overclock using the ASRock BIOS overclocker to 4.5 GHz even with my stock cooler?
2. What's the average temp for this setup idle and under load?
3. I was overclocking and only got up to 250 FPS on League of Legends. Why not more?
Thank you for your help.
P.S. I have two intake fans in the front and one exhaust in the back.
Nocturna(Main Computer): CPU: i7-4790K    GPU: MSI GTX 970 4G    MOBO: ASRock Fatal1ty Z97 Killer     PSU: CX500(For Now!)    Case: Enthoo Pro M    RAM: N/A(I don't really know anything other than it's 12GB total, it's a mixture...)    CPU Cooler: Stock i7-4790K Cooler(For Now!)
UPGRADES IN PROGRESS:
PSU: EVGA SuperNOVA 750 P2 80+ PLATINUM  RAM: Corsair Vengeance Pro 16GB DDR3 2133 MHz   CPU Cooler: Corsair Hydro Series H100i v2  GPU: GTX 980 Ti
https://linustechtips.com/topic/560372-i7-4790k-info/
You can OC on a Z97 Fatal1ty Killer board with your 4790k, whether you reach 4.5 is dependent on your voltage, chip and cooling. I would never go above 4.2Ghz with the stock cooler. Even a $25 air cooling solution will give you a decent kick up to 4.5Ghz without too much excess heat.
NCASE M1 i5-12600kf  RTX 4060Ti FE Z690M-ITX  SF600 NH-L9x65 Chromax  LPX 32GB
https://linustechtips.com/topic/560372-i7-4790k-info/#findComment-7374457
