I'm going to be starting my first real build from scratch soon.
I have only really upgraded my existing one but I've helped a friend put his together
I have some idea on what i need/want to get but if anyone can give some advice or help that wold be great
Case: Cooler Master Master Case 5 Pro
Top Case fans: Silencio FP 120 PWM Performance Edition 2x
Back case fans: Silencio FP 120 PWM Performance Edition 1x
Front case fans: Silencio FP 120 PWM Performance Edition 3x
PSU: Corsair RM1000x
Motherboard: ASUS ROG MAXIMUS VIII FORMULA/HERO
DDR4 RAM | Minimum 8GB
CPU: 6th Generation Intel Core i7 6700k 4GHz | Socket: LGA1151 | 8MB cache
CPU cooling: Cooler Master MasterAir Maker 8
GPU/s: 2 ASUS STRIX GTX 950 in SLI
Storage: (OS): Samsung 850 PRO 128GB SSD | (Games): SanDisk 480GB SSD | (Mass storage): WD Blue 3TB HDD
This is all copied from websites in case I typed it up wrong so don't moan for obvious facts about the hardware
I don't want to water cool (even though i put the motherboard with water cooling components on it in there), I'm to scared it will leak. I won't have any clue on what to do/get and no one is help me IRL so I'm sticking to air cooling
I know the GPUs aren't the best but I have a 950 in my current rig and don't want to buy 2 new cards. 1s enough.
I don't know what RAM to get so feel free to suggest things
Thanks for reading :D
https://linustechtips.com/topic/560222-my-first-build/
Would get an i5-6600k and 2x GTX 960 instead of the i7 and the 950s and only RM850x
CPU  i7-6700k @ 4.8 GHz  GPU Gigabyte GTX 980 Ti G1 Gaming 6GB Motherboard ASUS MAXMIMUS VIII RANGER  Case Phanteks Enthoo Evolv ATX  RAM 4 x 8GB HyperX Fury 32GB 2400 MHz  Cooling Corsair H110i PSU Be Quiet! Power Zone 1000W
https://linustechtips.com/topic/560222-my-first-build/#findComment-7373034
Swap out the 950's in SLI for a 380X or a 390, never SLI or CrossFireX a low end GPU, it's not worth it.
        Pixelbook Go i5 Pixel 4 XL
https://linustechtips.com/topic/560222-my-first-build/#findComment-7373048
I would get this as a first build:
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($245.99 @ SuperBiiz)
CPU Cooler: be quiet! Dark Rock 3 67.8 CFM Fluid Dynamic Bearing CPU Cooler  ($74.90 @ Newegg)
Motherboard: Gigabyte GA-Z170XP-SLI ATX LGA1151 Motherboard  ($118.75 @ OutletPC)
Memory: Kingston HyperX Fury Black 16GB (2 x 8GB) DDR4-2133 Memory  ($65.99 @ SuperBiiz)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($86.75 @ OutletPC)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.89 @ OutletPC)
Video Card: EVGA GeForce GTX 960 4GB SuperSC ACX 2.0+ Video Card (2-Way SLI)  ($204.99 @ NCIX US)
Case: Cooler Master MasterCase Pro 5 ATX Mid Tower Case  ($131.14 @ Amazon)
Power Supply: Corsair RMx 850W 80+ Gold Certified Fully-Modular ATX Power Supply  ($163.99 @ Newegg)
Total: $1347.38
Generated by PCPartPicker 2016-03-05 18:56 EST-0500
https://linustechtips.com/topic/560222-my-first-build/#findComment-7373067
First off: thanks for actually replying those who did, and giving suggestions. I wanted to clear some of the reasons why I picked those parts.
The reason i picked out that PSU is because I don't know how much all of the components will draw from the wall (Its the only thing i didn't check/work out) and it seams high enough that I can get new, better GPUs in the future.
I would get a better card that 950s but as I said up top, I have one already so its just to keep the price lower. I've only had the card for give or take 4 months so its fine right now.
That being said, I have looked into some 4gb 960s and I *might* be able to.
The reason why there is 3 separate drives is so I can have everything installed at once. I tend to install A LOT of mods for games like Fallout 4 and Skyrim and that takes up 1/5 of my storage right now so... yeah I want a lot of storage.
Finally, the reason why I want the i7 and not the i5 mainly due to the better clock speed and hyper-threading but also because the i7 isn't really that much more. The cheapest 4ghz clocked one i found (in 5 mins of searching) was £290 and the cheapest 6600k was £220 so quite close for minimal effort searching. I'm sure if I looked harder I could find one for £250 but for the matter of £70, It isn't that much but I might get the i5 if I start to get low on funds.
Thanks lads! :D
https://linustechtips.com/topic/560222-my-first-build/#findComment-7384566
