4 minutes ago, PH-G7 said:
I want to build a computer that will play current and future games smoothly at 1080p.
I was wondering if this is good.
http://pcpartpicker.com/p/cKRywP
Thanks for replying!
Good parts choice. The only thing I would change is to get at least a 120GB Samsung SSD. 64GB would fill out way to fast.
https://linustechtips.com/topic/560180-first-build-help/#findComment-7372438
 windows can be gotten for next to nothing. I would get a more spacious case to allow for more upgrades. but looks good
                   _/ V\
    ______|   __/_/| |
   /_______\______}\__}
[I5-12600k | 32gb DDR5 6000 | RTX5070 | 2x1tb M.2]
[Ryzen 5 1600 | 16gb DDR4 3200 | GTX1030 | 4x 8tb HDD]
https://linustechtips.com/topic/560180-first-build-help/#findComment-7372447
Just now, PH-G7 said:
I will only be using it for an OS.
Yeah, over time Windows writes files all the time and it will take up room. It's only $20 more. It's worth it. I have a Samsung 840 EVO 120GB and over 2 years of owning it, I only have 30GB left. (I keep all my games, videos, pictures, etc all on my HDD) Just a suggestion. Good luck with your build!
https://linustechtips.com/topic/560180-first-build-help/#findComment-7372451
I would get this instead:
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($245.99 @ SuperBiiz)
CPU Cooler: be quiet! Dark Rock 3 67.8 CFM Fluid Dynamic Bearing CPU Cooler  ($74.90 @ Newegg)
Motherboard: Gigabyte GA-Z170XP-SLI ATX LGA1151 Motherboard  ($118.75 @ OutletPC)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2400 Memory  ($72.88 @ OutletPC)
Storage: Kingston SSDNow V300 Series 240GB 2.5" Solid State Drive  ($64.89 @ OutletPC)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.89 @ OutletPC)
Video Card: Gigabyte GeForce GTX 970 4GB WINDFORCE Video Card  ($309.99 @ Newegg)
Case: Phanteks Enthoo Pro M ATX Mid Tower Case  ($59.99 @ Newegg)
Power Supply: EVGA SuperNOVA G2 650W 80+ Gold Certified Fully-Modular ATX Power Supply  ($99.99 @ NCIX US)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  ($19.89 @ OutletPC)
Operating System: Microsoft Windows 10 Home OEM (64-bit)  ($87.95 @ OutletPC)
Wireless Network Adapter: TP-Link TL-WDN4800 802.11a/b/g/n PCI-Express x1 Wi-Fi Adapter  ($36.88 @ OutletPC)
Monitor: Acer S220HQLAbd 60Hz 21.5" Monitor  ($99.99 @ Amazon)
Keyboard: AZIO MGK1-K Wired Gaming Keyboard  ($69.99 @ Amazon)
Mouse: Corsair Raptor M45 Wired Optical Mouse  ($59.88 @ OutletPC)
Total: $1471.85
Generated by PCPartPicker 2016-03-05 17:01 EST-0500
CPU  i7-6700k @ 4.8 GHz  GPU Gigabyte GTX 980 Ti G1 Gaming 6GB Motherboard ASUS MAXMIMUS VIII RANGER  Case Phanteks Enthoo Evolv ATX  RAM 4 x 8GB HyperX Fury 32GB 2400 MHz  Cooling Corsair H110i PSU Be Quiet! Power Zone 1000W
https://linustechtips.com/topic/560180-first-build-help/#findComment-7372456
Ok thanks I will keep this in mind.
https://linustechtips.com/topic/560180-first-build-help/#findComment-7372457
If you are trying to sell me on AMD go for it. What would be a reasonable alternative?
390, and I´m not trying to sell you one. These are actual factors one should consider when buying a computer. If you live in a place where you need to save every watt you can, then go for the 970 by all means. If you need cuda,(For certain rendering applications take advantage of it.) by all means 970. If you can live without the small boost in rendering, and power isn´t a fortune, I genuinely recommend a 390, since it tends to be cheaper and on avg. performs slightly better.
https://linustechtips.com/topic/560180-first-build-help/#findComment-7372545
Ok I will look into it. I guess I'll think back to algebra where you make those graphs like when will option a be cheaper than option b if option a cost this much to buy and this much per month and option b cost this much less but this much more per month. lol
https://linustechtips.com/topic/560180-first-build-help/#findComment-7372570
Ha, wasn´t actually trying to make that connection but it works. Just be aware, it´s possible Nividia might (For lack of a better term) gimp Maxwell when Pascal comes out.
https://linustechtips.com/topic/560180-first-build-help/#findComment-7372581
