Shroud is blocking GPU fan
By
TheDeathEffect
in Cases and Mods
in Cases and Mods
Solved by TheDeathEffect,
Found the problem. The screws on the XSPC back-plate are really long, and there's a specific one under the fan that was actually pushing it up. The plastic part warped away from the PCB on the fan, but I used a hair dryer to mold it back into place.
Thanks for the help
l3eyond ·
1
Serendipity1344 ·
Posted in Graphics Cards4 -
1
1
5
1
toxic_worper ·
Posted in New Builds and Planning9
