Gpu power supply cable
Go to solution Solved by shadowbyte,
the two extra detachable pins are used for the 8-pin connecter. They all go in.
For the 6-pin, just plug in the larger one, leaving the extra 2-pin one hanging
Snorlax: i7 5820k @4.5ghz, Asus X99 Pro, 32gb Corsair Vengeance LPX 2666, Cryorig R1 Ultimate, Samsung 850 evo 500gb, Asus GTX 1080 ROG Strix, Corsair RM850x, NZXT H440, Hue+
Smallsnor: Huawei Matebook X
Canon AE-1 w/ 50mm f/1.8 lens
Pentax KM w/ 55mm f/1.8 SMC lens
Zenit-E w/ 58mm f/2 Helios lens
Panasonic G7 with 14-42mm f/3.5 lens
Polaroid Spectra System
https://linustechtips.com/topic/559694-gpu-power-supply-cable/#findComment-7367107
