i just installed my gtx 960 and hoped on csgo to play a game with higher fps when i got in the game the fps was lower then my gtx 750 it was around 90 fps on low and i have installed all the latest drivers and i cant find a fix for my problem anywhere. hopefully someone has the answer to my problem.
https://linustechtips.com/topic/559638-help-please/
Just now, Lakeh said:
should i delete it?
Alright chillax. Can you get us a picture of the back of your PC?
Main PC |CPU - i7-6700k|GPU - R9 290x tri-x 4gb|RAM - 16gb ddr4|MOBO - MSI z170 - A PRO|HDD - WD 1TB/240gb Sandisk |PSU - 700w Raidmax
Laptop |CPU - i7 4720hq|GPU - 960m 2gb|Ram - 8gb 2x4|Model - y50-70 Touch|SSD - 240gb Patriot drive|Display - 1920x1080 IPS touch
https://linustechtips.com/topic/559638-help-please/#findComment-7366272
the vga is connected to the graphics card i dont have a camara
hmmm is vga your only option? Also what CPU do you have? AND do you have vsync enabled on csgo?
https://linustechtips.com/topic/559638-help-please/#findComment-7366287
Just now, Shadow Gamer said:
Have you modified any other hardware besides the GPU? And which Windows version are you using?
that shouldnt be an issue its a source game i mean it should run on windows xp if needed
https://linustechtips.com/topic/559638-help-please/#findComment-7366297
i ment dvi cord is what im using
Ok that wasnt the main issue. What cpu do you have and do you have vsync enabled on csgo?
https://linustechtips.com/topic/559638-help-please/#findComment-7366310
i dont have vsync enabled and i have a athlon 860k
what FPS do you get on the highest settings?
https://linustechtips.com/topic/559638-help-please/#findComment-7366326
around 90-130
around 90-130 on everthing maxed
well... there doesnt seem to be an issue... What resolution are your running.. You SHOULD be getting higher FPS but if your on higher than 1080p then that could do it
https://linustechtips.com/topic/559638-help-please/#findComment-7366365
someone told me to change my power manegement in nvidea control do you have to restart your PC for that to take effect?
https://linustechtips.com/topic/559638-help-please/#findComment-7366380
just restart your PC
https://linustechtips.com/topic/559638-help-please/#findComment-7366456
