Hey Guys
I'm planning on building a new PC but i'm not to sure on what to get in terms of a CPU, I've got a GPU that i will be using but i'm not sure what CPU to base my build around.
the reason for building a new PC is so i can run more CPU intensive games like Arma 3 and planet side 2
Cheers
edit: budget is under $1500 AUD
the only thing i don't need to buy is a GPU (Geforece GTX 670)
https://linustechtips.com/topic/559499-build-recomendations/
It would help if I knew the rest of your build. Side note: Arma 3 is not very CPU intensive, I have a i7 6700k and while in a game Arma 3 only uses about 40% of my CPU. That is lower than most games I play.
CPU: i7 6700k | Motherboard: MSI Z170A Gaming M7 | RAM: 16GB DDR4 G.Skill RipJaws V @ 2400mhz | GPU: MSI GTX 980 Twin Frozr | Case: Corsair 300r windowed | Storage: 1TB HDD and 128GB SSD | PSU: Corsair RM850i | Monitor: BenQ xl2420z | Cooler: Corsair h60 | Sound: Astro A40 | Mouse: Razer Taipan | OS: Win 8.1 | PCPartPicker Link: http://ca.pcpartpicker.com/p/xV7tZL
https://linustechtips.com/topic/559499-build-recomendations/#findComment-7363532
Arma 3 is really cpu intensive, but you happen to have the best cpu for it
https://linustechtips.com/topic/559499-build-recomendations/#findComment-7363557
I used to have a i5 4670k and it only used about 50% and I got the same frame rate. I was comparing the usage of Arma 3 compared to other game. For example: Arma 3 uses about 40% of my CPU as where as games like GTA V, Cities Skylines, ETC uses about 60% or so. Arma 3 uses less than most games.
https://linustechtips.com/topic/559499-build-recomendations/#findComment-7363585
I think for you, a newer i5 would work.  Honestly, unless you're doing content creation an i7 is overkill imo
// Floatplane Pilot //
Main Rig:  Motherboard: ASUS H270 - PLUS - CSM | RAM: Corsair Vengeance DDR4 16GB (2x8GB) | Case: Corsair Carbide Series SPEC - 02 | SSD: ADATA SU800 128GB HDD: WD 1TB Hard Drive | PSU: Corsair CX 550M | CPU: Intel Core i7-7700 Cooling: Cooler Master Hyper 212 EVO | GPU: ASUS GeForce GTX 1070 | Keyboard: Logitech G710+ Mechanical | Mouse: Razer Naga 2014 | Sound: Corsair VOID RGB / USB Headset | OS: Windows 10
Laptop:   Razer Blade Stealth 2016
https://linustechtips.com/topic/559499-build-recomendations/#findComment-7363613
if you can afford a 6600k or a 6700k i would get one of those. overclocking significantly increases gaming performance. there's no doubt in my mind. my overclocked cpu performs way better than when it's set to stock
https://linustechtips.com/topic/559499-build-recomendations/#findComment-7363658
