Need help with a program
Cryosec
I'm coding a program that will extract the text from a specific HTML tag in webpages loaded by url from a file (around a hundred links). The problem is, I have no idea how to go throu the HTML source of each webpage, read the text from the specific (and only one in the page) tag and eventually delete unwanted text (I need numbers, but there could be unnecessary text with it).
What would be the best language to use? And how can I do it?
Computer Case: NZXT S340 || CPU: AMD Ryzen 5 1600 || Cooler: CM Hyper212 Evo || MoBo: MSI B350 Mortar || RAM Vengeance LPX 2x8GB 3200MHz || PSU: Corsair CX600 || SSD: HyperX Fury 120GB & 240GB || HDD: WD Blue 1TB + 1TB 2.5'' backup drive || GPU: Sapphire Nitro+ RX 580 4GB
Laptop 1 HP x360 13-u113nl
Laptop Lenovo z50-75 with AMD FX-7500 || OS: Windows 10 / Ubuntu 17.04
DSLR Nikon D5300 w/ 18-105mm lens
maybe try php5
"Learn from yesterday, live for today, hope for tomorrow. The important thing is not to stop questioning." -Albert Einstein
What language(s) do you know already? Chances are you won't need to learn a new language just for this task.
Look into web scraping.
C++, Python and Java. I'm still learning other languages, so just these for the moment.
In Java you could use something like Jsoup. It can fetch the page from URL and parse it for you. Syntax is very easy, you just have to give it a CSS selector to get some HTML element.
I'll try this out, thanks
17 minutes ago, Gachr said:
Unless the website is so malformed a real parser won't work or you're trying to parse inline JS, using regex on html is a pretty bad idea.
Using an html / xml parser like the ones @madknight3 listed will be much easier, less prone to breaking on small changes to the website and be faster.
1474412270.2748842
