can you guys recommend me Headphone for listening to Songs ?, i mostly listen to Rap Song, and it must Over-Ear, its better if it has Mic if it doesn't its okay, and its for game too, under range 200-250US$, i already has Xonar Phoebus Soundcard
Key Switches Guide | LLT Beginner Guide | GPU TDP & Power Consumption Explained | PSU Tier
s a d b o y s 2 0 0 1
https://linustechtips.com/topic/559001-headphone-recommendation/
Well if it has a mic it is a headset not headphone. look at the sennheiser game zero/one if you want headset.
Before you buy amp and dac.  My thoughts on the M50x  Ultimate Ears Reference monitor review I might have a thing for audio...
My main Headphones and IEMs:  K612 pro, HD 25 and Ultimate Ears Reference Monitor, HD 580 with HD 600 grills
DAC and AMP: RME ADI 2 DAC
Speakers: Genelec 8040, System Audio SA205
Receiver: Denon AVR-1612
Desktop: R7 1700, GTX 1080  RX 580 8GB and other stuff
Laptop: ThinkPad P50: i7 6820HQ, M2000M. ThinkPad T420s: i7 2640M, NVS 4200M
Feel free to pm me if you have a question for me or quote me. If you want to hear what I have to say about something just tag me.
https://linustechtips.com/topic/559001-headphone-recommendation/#findComment-7355288
Just now, Carde said:
Sennheiser Game one for a headset (avoid the zero)
Sennheirser Momentum over ear for just headphone.
My limited view :)
Why should he not look at the zero??
https://linustechtips.com/topic/559001-headphone-recommendation/#findComment-7355322
When indoors the open design gives a nicer sooner and better immersion than the closed design of the zero.
O and I don't like the leather, but that is personal :)
"Hope, what a concept." - Deunan Knute
https://linustechtips.com/topic/559001-headphone-recommendation/#findComment-7355334
But if he needs isolation then the one is not for him. If he is in a silent or close to silent room he should look at open headphones or headsets if he is in a noisy room look closed. I can kinda hear that you are a little new to all of this am I right?  (not to be mean)
https://linustechtips.com/topic/559001-headphone-recommendation/#findComment-7355365
OP check this guide out SSL has made for headphones you just need to add a mod mic and boom you have a nice pair of headphones with a good mic.
https://linustechtips.com/topic/559001-headphone-recommendation/#findComment-7355393
The stickied thread is most current, I'll take down the blog post which I'm not updating at this point.
https://linustechtips.com/topic/559001-headphone-recommendation/#findComment-7355444
Well okay..
https://linustechtips.com/topic/559001-headphone-recommendation/#findComment-7355452
well iam in quite room, so go for One ?
Thanks
https://linustechtips.com/topic/559001-headphone-recommendation/#findComment-7356670
sennheiser 598?? or even 600 series?
Current Build :
CASE: Fractal Design R4 w/Window CPU: Intel 4930K,  RAM: 16GB Ripjaws Z 2133Mhz  Cooling: H100i  MotherBoard: Asus P9x79 Pro , PSU: CS750M   Storage: 2x Samsung 840 Pro 256Gb , 1Tb Seagate Barracuda, 500GB WD Black,  Graphics: Gigabyte GTX 780 Windforce 3GB,  Monitors: AOC G2460PG ( G sync monitor), Edge10 24" 1080p , 24" 1680*1020p monitor ( LCD)  Microphone: Blue Yeti  Keyboard: Cougar 700k  Phone: Samsung Note 3  Headphones: Sennheiser HD598
Laptop:
 CPU:
4710MQ  Ram: 8GB 1600MHz Storage:120Gb 840 Evo + 1Tb 5400Rpm HDD  Graphics: GTX 850M 2GB   Screen: 1080p IPS
https://linustechtips.com/topic/559001-headphone-recommendation/#findComment-7356896
