Hello forums,
My pc started to fail te recognize my boot drive, i have to re-assign the drive in the bios. After doing that it works for a few boots (1-10). And then i have to assign it again.
I can see both drives in my bios, but for some reason it doesnt boot from the SSD. (it shows my HDD (without windows) in my bios as the boot drive)
Things i have done:
Used diffrent sata connectors on my mobo.
Changed both cables to the drive.
my setup:
  • CPUIntel I7-6700K 4.6 ghz
  • MotherboardAsus Maximus VIII Ranger
  • RAM2×8 GB corsair vengeance LPX DDR 4 2666 MHz
  • GPUMSI Radeon R9 280X GAMING 3GB
  • Casecooler master haf 922 plus
  • Storageseagate 2TB 7200RPM and Crucial MX100 512GB
  • PSUCooler Master V700
Operating SystemWindows 10
Thanks in advance for any help
https://linustechtips.com/topic/558970-bootdrive-not-recognizing/
try change it to AHCI in the bios and if this doesn't work then update the bios
Main build
CPU: i7 5820k  MotherBoard: Gigabyte x99 UD4  RAM: corsair ballistix 2400mhz 4x4gb  GPU: Asus GTX 970  PSU: corsair rm1000  SSD 1: Samsung 840evo 500gb  SSD 2: Samsung 850evo 500gb  HDD: Western Digital red 3tb  Case: Phanteks Enthoo pro M  CPU cooler: corsair h80i
Second build
CPU: i7 5820k  MotherBoard: Gigabyte x99 UD5 WIFI  RAM: G.skill 2666mhz 4x4gb  GPU: Nvidia GTS 450 (soon to be upgraded)  PSU: corsair HX650  SSD: Samsung 850evo 250gb  Case: Cooler Master 430 elite  CPU cooler: Cooler Master hyper 212 evo
Third build
CPU: xeon x5690  MotherBoard: Evga x58 classified 4way-sli  Ram: Patriot 1600mhz 4x3gb  GPU: Asus HD6970  PSU: fractal newton r2 1000w  SSD: crucial m500 240gb  Case: Cooler Master Haf X  CPU cooler: Mega Shadow
The problem is still there after setting it to AHCI.
The bios update program "Asus EZ update" tells me there are no updates available.
NOTE: the exact error message i get while booting is: "MBR error 1"
