Network issue
Go to solution Solved by ThyFeared,
3 minutes ago, Nerdtality said:
You can contact Comcast via
+1 (800) 934-6489
2 minutes ago, HdFkK said:
You might have to go the classic route of eliminating potential errors. Switch cables, get a cheap network card/network usb adapter to see if its just the ethernet port on your motherboard is gone and so on..
The switch I have upstairs completely shit itself so I replaced it. I totally forgot about it. Thanks for help though !
I'm getting a network issue coming up as one or more protocols are missing. I've tried editing the registry and netsh winsock reset. Neither of them worked. I updated windows yesterday and I got on one time last night and everything was flawless. I turn my pc on this morning nothing works at all. If you need more info just ask me
https://linustechtips.com/topic/558915-network-issue/
Do you get an error?  What is happening, complete loss of network connectivity? What is your connection status?
- ASUS X99 Deluxe - i7 5820k - Nvidia GTX 1080ti SLi - 4x4GB EVGA SSC 2800mhz DDR4 - Samsung SM951 500 - 2x Samsung 850 EVO 512 -
- EK Supremacy EVO CPU Block - EK FC 1080 GPU Blocks - EK XRES 100 DDC - EK Coolstream XE 360 - EK Coolstream XE 240 -
https://linustechtips.com/topic/558915-network-issue/#findComment-7354531
Make sure your networking cable(s) are not damaged, from there we can go further if that did not help.
   / | / /__  _________/ / /_____ _/ (_) /___  __
  /  |/ / _ \/ ___/ __  / __/ __ `/ / / __/ / / /
 / /|  /  __/ /  / /_/ / /_/ /_/ / / / /_/ /_/ /
/_/ |_/\___/_/   \__,_/\__/\__,_/_/_/\__/\__, /
                                        /____/
Hi, 「Neͥrdͣtͫality」noice to meet you... :3
https://linustechtips.com/topic/558915-network-issue/#findComment-7354551
+1 (800) 934-6489
                                        /____/
https://linustechtips.com/topic/558915-network-issue/#findComment-7354609
You tell me! Who is your daddy and what does he do?
Systems:
  • Silent-WS: 5820k@4,5GHz, 32GB Klevv Cras white DDR4, Titan X Pascal@EKWB, Asus X99 E-WS 3.1, 512GB 950Pro, Caselabs Merlin SM8, Seasonic Prime 850W
  • MacBook: 15" Retina Late 2013
  • Tablet: iPad Pro 10.5"
  • Network Storage: -
https://linustechtips.com/topic/558915-network-issue/#findComment-7354610
+1 (800) 934-6489
https://linustechtips.com/topic/558915-network-issue/#findComment-7354640
