So my new sound card came in the mail today and I installed it in my computer and installed the drivers. At first everything was working fine but after the first reboot, the sound card stopped working. I checked all the cables and they are in their correct positions. What should I do? This is the sound card: http://www.newegg.com/Product/Product.aspx?Item=N82E16829271007
https://linustechtips.com/topic/55878-sound-card-wont-work/
Disable On-board, try another slot, reseat, try in anothyer system. If all fails, RMA.
Andres "Bluejay" Alejandro Montefusco - The Forums Favorite Bird!!!
Top Clock: 7.889 Ghz Cooled by: Liquid Helium
#ChocolateRAM #OatmealFans #ScratchItHarder #WorstcardBestoverclocker #CrazySexStories #SchnitzelQuest TS3 SERVER
https://linustechtips.com/topic/55878-sound-card-wont-work/#findComment-753563
What ^ They said. Plus go into Windows Sound settings and make sure it's enabled as your default sound device.
X-10 - 7980XE - Gigabyte Aorous Gaming 9 - 128GB GSkill TridentZ RGB - SLI Asus GTX 1080 TI Strix
Easy Desk GuideMalware Removal Guide - New mobo, Same OS Guide
https://linustechtips.com/topic/55878-sound-card-wont-work/#findComment-753606
