Just now, Attis said:
Hi,
I have just started using my new built pc and after an hour the pc started being hot, even the case is warm
Is this normal?
Depends on the actual temps of your components. A general warmup is normal; afterall, the electrical energy has to go somewhere....
Want to help researchers improve the lives on millions of people with just your computer? Then join World Community Grid distributed computing, and start helping the world to solve it's most difficult problems!
https://linustechtips.com/topic/558648-hot/#findComment-7351698
2 minutes ago, Attis said:
Hi,
Is this normal?
if you can't figure out exactly what your temps are, you can use open hardware monitor. It will tell you the temps within your computer. 75 degrees celsius and lower is perfectly normal.
You know how it is, the cow goes "moo", the dog goes "woof" and the gamer goes "The PvP is unbalanced."
Personal Computer: CPU: i7-4790 Mobo: Asrock Z97 Extreme6 Graphics Card: MSI R9-380  Memory: 16GB (8GB x2) G. Skill Sniper Gaming Series PSU: Apevia Warlock 750W Case: NZXT Phantom 410 Series Storage: 240GB SSD (OS) 3TB HDD (data and such) 500 GB SSD (Movies and Large Data Transfers (I'm constantly moving this one around to other computers))
https://linustechtips.com/topic/558648-hot/#findComment-7351710
Also, this may seem um.. unnecessary? but make sure you have exhaust fans.. Not trying to seem like I'm insulting anyone's intelligence, just have made that mistake before way in the past.
 CPU: Intel Core i5 6600K  Motherboard: Asus Z170-A  CPU Cooler: Corsair H110i GT  GPUGigabyte GTX 980 Xtreme  RAM:2x8gb HyperX Fury  SSD: 120gb A-Data  HDD: 1Tb WD Blue 7200RPM - 750gb Hitachi 2.5" HDD  PSU: EVGA SuperNova G1 650W  Case: Phanteks Enthoo Evolv ATX  Monitor: 27" AOC LED IPS x 2  Keyboard: Corsair Strafe RGB Silent  Mouse: Corsair Scimitar RGB
 HeadsetLogitech G430
https://linustechtips.com/topic/558648-hot/#findComment-7351712
If by system fans you mean case fans, then yes, either go with balanced or positive pressure inside the case 1: for good airflow and 2: keep those nasty lil dust particles out.
https://linustechtips.com/topic/558648-hot/#findComment-7351730
Yea I have 1 of those getting another in a week
That's probably the issue then, If you're not moving that hot air out of there, the whole thing is going to heat up fairly fast. I typically go with 3 "case fans" 2 intake and 1 exhaust (not including my exhaust from my cpu cooler)
https://linustechtips.com/topic/558648-hot/#findComment-7351750
So its normal to have the case warm since i only have 1 fan?
https://linustechtips.com/topic/558648-hot/#findComment-7351763
I wouldn't say "normal". However, it is expected.
https://linustechtips.com/topic/558648-hot/#findComment-7351769
6 hours ago, Attis said:
The temp is fine but the case is so warm, is that normal?
Whats your setup? Hardware and fans, case too. If its smaller case with GPU and CPU cooler right next to case walls, it will get bit warm. Also side behind mobo will get bit warm right under where CPU is. Its actually good thing since you steel case acts as dissipation surface for heat.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/558648-hot/#findComment-7352920
1 hour ago, LukaH said:
The simple answer here is... all the components are producing heat when the pc is on so yes if the case gets warm it is normal.... If you can grill a steak on it then it is not normal.
Maybe it's the aluminum panels on my case, but it has always felt like cold metal to me with proper airflow.
https://linustechtips.com/topic/558648-hot/#findComment-7355814
yeh got cold metal as well here
but he did not mention which case he is using for all we know it could be a raven or a node 202 which would not be surprising if it is getting warm :P
GPU drivers giving you a hard time? Try this! (DDU)
https://linustechtips.com/topic/558648-hot/#findComment-7355863
17 minutes ago, Attis said:
It's a fractal case 1300
Okay, being a Micro ATX chassis it probably will get warm-ish, However, From the reviews i've seen on it, it has exceptional airflow and even good watercooling support, which brings me back to the fans.... From what i saw it comes with 2 case fans out of the box, yours didn't?
https://linustechtips.com/topic/558648-hot/#findComment-7356109
where do you keep it, is it in a well ventilated area? also what cooler and gpu are you running? also i went to check on my HTPC witch is in a mATX CM Selencio 352 with only the integrated gpu on the motherboard, and a phenom 955 with a "better than stock cooler" and some HDDs. The system is mostly idling and it has two intake fans Fractal Design something and one exhaust fan and the whole case is warm to the touch but the temps are fine so i would not worry about it.
Should have thought of this sooner.
https://linustechtips.com/topic/558648-hot/#findComment-7356388
My mobi has only 1 slot for a fan so I have to buy a a cord to connect the other fan
https://linustechtips.com/topic/558648-hot/#findComment-7356461
