Crappy SSD. The Adata SP550 or the Sandisk SSD Plus are better choices.
Personally, I'd try to aim for a cheaper PSU and case to get an 980Ti instead of the 980.
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($374.95 @ B&H)
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler
Motherboard: MSI Z170A KRAIT GAMING ATX LGA1151 Motherboard  ($139.99 @ Amazon)
Memory: Kingston HyperX Fury Black 16GB (2 x 8GB) DDR4-2133 Memory  ($65.99 @ SuperBiiz)
Storage: A-Data Premier SP550 120GB 2.5" Solid State Drive  ($38.99 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.89 @ OutletPC)
Video Card: Gigabyte GeForce GTX 980 Ti 6GB WINDFORCE 3X Video Card  ($599.99 @ Amazon)
Case: Cooler Master MasterCase Pro 5 ATX Mid Tower Case  ($131.14 @ Amazon)
Power Supply: EVGA SuperNOVA P2 650W 80+ Platinum Certified Fully-Modular ATX Power Supply  ($66.99 @ NCIX US)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  ($19.89 @ OutletPC)
Total: $1487.82
Generated by PCPartPicker 2016-03-02 19:53 EST-0500
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/558646-white-build/#findComment-7351709
Very nice build, I'm getting that same case soon and have a 980ti with that same cooler.  The cooler is very good and silent under all but the heaviest loads.
R9 5900X | 32 GB DDR4 3600 | ASUS Crosshair VIII DarkHero | EVGA RTX 3080 FTW3 | 2x 1TB WD Black SN850 | Lian Li O11D-XL | Corsair AX1200i
https://linustechtips.com/topic/558646-white-build/#findComment-7351719
Total: $1487.82
I know its shit I am not geting it
https://linustechtips.com/topic/558646-white-build/#findComment-7351727
So what are you actually buying?
https://linustechtips.com/topic/558646-white-build/#findComment-7351736
https://linustechtips.com/topic/558646-white-build/#findComment-7351747
14 minutes ago, Will Or occ said:
Hey i have sent in stone some of my parts.
http://pcpartpicker.com/p/QVMmnQ
1st. will it all work?
2ed. I am trying to do a white/black build with this so if you try to re make the build with a white with a little of black that would be alsome!! thanks!!!
There you go...here is a 980 that is black and white: http://pcpartpicker.com/p/rgXd3C
https://linustechtips.com/topic/558646-white-build/#findComment-7351756
edit: wrong link
You tell me! Who is your daddy and what does he do?
Systems:
  • Silent-WS: 5820k@4,5GHz, 32GB Klevv Cras white DDR4, Titan X Pascal@EKWB, Asus X99 E-WS 3.1, 512GB 950Pro, Caselabs Merlin SM8, Seasonic Prime 850W
  • MacBook: 15" Retina Late 2013
  • Tablet: iPad Pro 10.5"
  • Network Storage: -
https://linustechtips.com/topic/558646-white-build/#findComment-7351765
1 minute ago, HdFkK said:
http://pcpartpicker.com/parts/partlist/
This is as white as it gets for MB, Cooler, Ram and GPU. Man I wish I could build this one..
Wrong link, you want the permalink above the build list.
do you have any white builds? that have same specs?
Budget? I've already suggested a white and black build above.
https://linustechtips.com/topic/558646-white-build/#findComment-7351777
http://pcpartpicker.com/p/DH9Xgs
There you go, I am sorry :D
That 980ti HoF would really stand out I think!
Systems:
https://linustechtips.com/topic/558646-white-build/#findComment-7351782
