Just now, DaltonM said:
Are they hooked into the motherboard anywhere? Fans that hooked directly to the PSU can't be controlled and only run at full speed or just off.
If you have some fans that hooked directly to the PSU, you're going to need a fan controller module
I think thr front fans are hooked to the psu because top and bottom i can control
https://linustechtips.com/topic/558567-fans/#findComment-7350915
If they're hooked to the PSU, you cannot control them and they will always run at 100%.
USEFUL LINKS:
PSU Tier List F@H stats
https://linustechtips.com/topic/558567-fans/#findComment-7350930
