I think it's a beautiful and well thought out concept!
  1. GLaDOS: i5 6600 EVGA GTX 1070 FE EVGA Z170 Stinger Cooler Master GeminS524 V2 With LTT Noctua NFF12 Corsair Vengeance LPX 2x8 GB 3200 MHz Corsair SF450 850 EVO 500 Gb CableMod Widebeam White LED 60cm 2x Asus VN248H-P, Dell 12" G502 Proteus Core Logitech G610 Orion Cherry Brown Logitech Z506 Sennheiser HD 518 MSX
  2. Lenovo Z40 i5-4200U GT 820M 6 GB RAM 840 EVO 120 GB
  3. Moto X4 G.Skill 32 GB Micro SD Spigen Case Project Fi
https://linustechtips.com/topic/558561-my-first-pc-modding/#findComment-7350774
Just now, PlexiTube said:
Why is the radiator pushing air into the case rather than exhausting?
or is it solid underneath the radiator and its expelled out the sides?
https://linustechtips.com/topic/558561-my-first-pc-modding/#findComment-7350781
9 minutes ago, PlexiTube said:
-SNIP-
Oh really nice, like the top cover type design.
As for ideas any thoughts about adding some optional mounting points for rads along the spacer rods to the top plate, for possibly for hybrid based GPU's or a second option for a rad location. (side mount kind of idea)
Edited by W-L
https://linustechtips.com/topic/558561-my-first-pc-modding/#findComment-7350801
yes, it expelled out the sides :-)
that makes way more sense now. I thought there was more internals below that main surface. Awesome concept.
https://linustechtips.com/topic/558561-my-first-pc-modding/#findComment-7350855
depending on price, I would totally buy one for a future build. Seems like it would make a good test bench.
You know how it is, the cow goes "moo", the dog goes "woof" and the gamer goes "The PvP is unbalanced."
Personal Computer: CPU: i7-4790 Mobo: Asrock Z97 Extreme6 Graphics Card: MSI R9-380  Memory: 16GB (8GB x2) G. Skill Sniper Gaming Series PSU: Apevia Warlock 750W Case: NZXT Phantom 410 Series Storage: 240GB SSD (OS) 3TB HDD (data and such) 500 GB SSD (Movies and Large Data Transfers (I'm constantly moving this one around to other computers))
https://linustechtips.com/topic/558561-my-first-pc-modding/#findComment-7350861
Thanks , I really appreciate , I designed and built this pc case based on my new hardware , your proposals are interesting , but if in the future I will need a different set , I would change it myself ;-)
Any change will be possible ...
I personally cut plexiglass with my laser machine :-)
https://linustechtips.com/topic/558561-my-first-pc-modding/#findComment-7357268
