Will this GPU:
EVGA NVIDIA GTX 750 Ti SC Mini ITX GAMING Graphics Card - 2GB
02G-P4-3753-KR - 2GB EVGA GTX 750Ti SC GAMING Mini ITX, PCIe 3.0, 5400MHz GDDR5, GPU 1176MHz, Boost 1255MHz, Cores 640, DP/HDMI/DVI-IGo
Go with my packet computer?
http://support.hp.com/fi-fi/document/c03177674
EDIT: My computer uses DDR3
https://linustechtips.com/topic/558459-will-it-go-together/
1 minute ago, QueenDemetria said:
it should work.
Yep, physical measurements and connectors check out. It's a pre-built computer which can come with all kinds of ungodly designed internals, so I would get your new card from somewhere you can return it to in the event that it won't work out, just in case.
Lenovo Ideapad 720s 14 inch ------ One day I'll have a desktop again...
https://linustechtips.com/topic/558459-will-it-go-together/#findComment-7349668
Recommend me ? I live in europe. (btw cute owl <3)
https://linustechtips.com/topic/558459-will-it-go-together/#findComment-7349674
Thanks (not mine). Never even been to europe, but I expect any decent local PC shop should have a 15 or 30 day return policy as long as you don't damage anything and have the receipt. Just ask someone there. Edit: Amazon should work as well.
https://linustechtips.com/topic/558459-will-it-go-together/#findComment-7349686
Your prebuilt already has a standard single slot card in it. If you've got 2 expansion slots, it will work .
MSI has a single slot 750 ti that's really good. I have it and use it. http://www.newegg.com/Product/Product.aspx?Item=N82E16814127836
https://linustechtips.com/topic/558459-will-it-go-together/#findComment-7349695
Will this do? https://www.scan.co.uk/products/2gb-evga-gtx-750ti-sc-gaming-mini-itx-pcie-30-5400mhz-gddr5-gpu-1176mhz-boost-1255mhz-cores-640-dp-h?utm_source=google+shopping&utm_medium=cpc&gclid=Cj0KEQiA0sq2BRDRt6Scrqj71vQBEiQAg5bj09sr2Ue0tgwlWrMiogVn4rVT2OeR2VURk3NXyZjcSs8aAgtH8P8HAQ
https://linustechtips.com/topic/558459-will-it-go-together/#findComment-7349696
So will MSI do for my computer?
https://linustechtips.com/topic/558459-will-it-go-together/#findComment-7349724
https://linustechtips.com/topic/558459-will-it-go-together/#findComment-7349726
If they have a return policy, I see no reason why not.
Dalton said something about expansion slots. Idk will that MSI go for my computer. What do you think?
https://linustechtips.com/topic/558459-will-it-go-together/#findComment-7349733
2 minutes ago, DaltonM said:
You're good to go as long as you have a full speed PCIE slot that will fit the 2 slot sized GPU. I suggest playing it safe with a single slot card. Can you post pics of the inside of the system with no GPU installed?
Taking out my GPU?
https://linustechtips.com/topic/558459-will-it-go-together/#findComment-7350006
