Android Root/Update problem
I've been out of the loop when it comes to rooting phones, but this is what I remember..
Get your phone into Download Mode or the equivalent of download mode based on the manufacturer of the phone. Get a piece of software that will help you flash the stock ROM back onto the device. For Samsung devices, it was ODIN...so find the equivalent to that. YOu also have to find a stock image...which will most likely be found on the XDA forums or other forums.
There is most likely a guide somewhere on XDA so I suggest you follow that since I just know the general procedures of root & unrooting android device, and not specific procedures for every device.
AS for recovering images, it is possible....but the software and instructions to do so are probably not available to consumers. When you first delete images, it isn't deleted, it is just allowed to be rewritten over by something else. But after resetting your phone, and probably flashing it now....a lot of those images, if not all, might have been rewritten over.
