Better Internet Solution?
2 minutes ago, Spork829 said:Before I switched out the motherboard, my old one which came from a pre-built PC had a Mini PCIE Wifi adapter with a little antenna on top, and that worked just fine. The Wifi in my room is fine, it's more a matter of the best way to enable this motherboard to use it.
Just now, Spork829 said:Okay, that might work. I'm gonna hop over to my local Microcenter today and see what they have. Mobo
ok good, i was worried that your Graphics card might cover up a mini pci slot (a problem with a lot fo mobos) But you should be able to get a PCI wifi card just fine! (pci wifi cards tend to be a lot better then usb wifi cards!) Try to pick up the one i linked as its popular and should be there. If not DO NOT CHEAP OUT on a wifi card. Make sure its a pci card and decent.
