so...I dont have it T_T
NoAdvancedOptions.pngif it helps I use an ECS H61H2-MV
System
  • CPU
    i3 3220 3.3GHz
  • Motherboard
    H61H2-MV
  • RAM
    8GB no name
  • GPU
    Radeon HD 4870
  • Case
    Thermaltake Core V21
  • Storage
    1TB HDD, 700gb HDD, 320gb HDD and 256gb SSD
  • PSU
    Corsair CX600
  • Display(s)
    Flatron L1960TR , MAG MS776I , ViewSonic VA903m ( all of them are 1280x1024,dad found em) and a Fujicom FJ-32V TV
  • Cooling
    1 200M front fan, and unknowen CPU tower(low profile)
  • Keyboard
    HP QY776AT
  • Mouse
    LUOM G10
  • Sound
    Jamo E 4 CEN, Jamo E470 and Jamo E410 with a KENWOOD S505D
  • Operating System
    Windows 10 Pro N
reinstall it? if i'm not wrong you shold find it on the motherboards website in downloads, i could probobly find it for you if i get the brand of the mobo aswell as the name of it
Main build
CPU: i7 5820k  MotherBoard: Gigabyte x99 UD4  RAM: corsair ballistix 2400mhz 4x4gb  GPU: Asus GTX 970  PSU: corsair rm1000  SSD 1: Samsung 840evo 500gb  SSD 2: Samsung 850evo 500gb  HDD: Western Digital red 3tb  Case: Phanteks Enthoo pro M  CPU cooler: corsair h80i
Second build
CPU: i7 5820k  MotherBoard: Gigabyte x99 UD5 WIFI  RAM: G.skill 2666mhz 4x4gb  GPU: Nvidia GTS 450 (soon to be upgraded)  PSU: corsair HX650  SSD: Samsung 850evo 250gb  Case: Cooler Master 430 elite  CPU cooler: Cooler Master hyper 212 evo
Third build
CPU: xeon x5690  MotherBoard: Evga x58 classified 4way-sli  Ram: Patriot 1600mhz 4x3gb  GPU: Asus HD6970  PSU: fractal newton r2 1000w  SSD: crucial m500 240gb  Case: Cooler Master Haf X  CPU cooler: Mega Shadow
I found it on ECS website and everything but when I downloaded the software it was basicliy the same,no advanced settings.
System
  • CPU
    i3 3220 3.3GHz
  • Motherboard
    H61H2-MV
  • RAM
    8GB no name
  • GPU
    Radeon HD 4870
  • Case
  • Storage
  • PSU
    Corsair CX600
  • Display(s)
  • Cooling
  • Keyboard
    HP QY776AT
  • Mouse
    LUOM G10
  • Sound
  • Operating System
    Windows 10 Pro N
that's really wierd since it should fix it. i can't really check it out since i don't have that version of realtek
Main build
Second build
Third build
im actually checking if what I wanted to do worked
what was actually the problem is audio skipping.
so now that im back on the main version I could see if it worked.
I will reply to you if what I wanted worked or not.
System
  • CPU
    i3 3220 3.3GHz
  • Motherboard
    H61H2-MV
  • RAM
    8GB no name
  • GPU
    Radeon HD 4870
  • Case
  • Storage
  • PSU
    Corsair CX600
  • Display(s)
  • Cooling
  • Keyboard
    HP QY776AT
  • Mouse
    LUOM G10
  • Sound
  • Operating System
    Windows 10 Pro N
@ExozeGD it didnt work T_T
System
  • CPU
    i3 3220 3.3GHz
  • Motherboard
    H61H2-MV
  • RAM
    8GB no name
  • GPU
    Radeon HD 4870
  • Case
  • Storage
  • PSU
    Corsair CX600
  • Display(s)
  • Cooling
  • Keyboard
    HP QY776AT
  • Mouse
    LUOM G10
  • Sound
  • Operating System
    Windows 10 Pro N
if you can find the .exe file for realtek then try to launch it with admin rights. this is the last thing i got
Main build
Second build
Third build
Didnt work.
System
  • CPU
    i3 3220 3.3GHz
  • Motherboard
    H61H2-MV
  • RAM
    8GB no name
  • GPU
    Radeon HD 4870
  • Case
  • Storage
  • PSU
    Corsair CX600
  • Display(s)
  • Cooling
  • Keyboard
    HP QY776AT
  • Mouse
    LUOM G10
  • Sound
  • Operating System
    Windows 10 Pro N
3 minutes ago, imkinger said:
Didnt work.
ok if this doesn't work then i must look at myself as defeated. try uninstalling it. restart your pc then installing an older version like one or two versions ago and then restart again.
Main build
Second build
Third build
allright,thanks bruh.
System
  • CPU
    i3 3220 3.3GHz
  • Motherboard
    H61H2-MV
  • RAM
    8GB no name
  • GPU
    Radeon HD 4870
  • Case
  • Storage
  • PSU
    Corsair CX600
  • Display(s)
  • Cooling
  • Keyboard
    HP QY776AT
  • Mouse
    LUOM G10
  • Sound
  • Operating System
    Windows 10 Pro N
