so i want to build a new rig and was wondering about the case, it's gonna be the regular ATX mobo,two HDD 3.5,a CM sedion 120mm CPU watercooler and...gtx 980ti waterforce (which is known to have a short liquid tubes)
so the case choices that i've come through are...
1-Corsair Carbide Series SPEC-03
2-NZXT S340
3-NZXT Phantom 240
i think the corsair spec 3 is the best choice as i can move the back fan to the bottom front and the GPU's cooler to the back and the CPU's to the top
but aside from installing fans and rads, what about other stuff ...like cable management or future upgrades
 what do you guys think?
https://linustechtips.com/topic/557323-help-me-choosing-a-case/
2-NZXT S340
3-NZXT Phantom 240
I have the S340 and like it because it is insanely easy to cable manage and hide the PSU.
Very useful if you don't have a modular PSU (me with my HCG 900).
Primary Build: i7-4790 · 16GB Hynix DDR3-1600 · Sapphire Tri-X R9 390x · NZXT S340 · Win10 Pro · Seagate Barracuda 1TB T_T
Portable: 2015 Retina Macbook Pro 13" · i5-5257u · 512GB PCIe SSD · Intel Iris 6100 T_T
If my post helped you, please rate it!
https://linustechtips.com/topic/557323-help-me-choosing-a-case/#findComment-7338245
