My FX-8320 during gaming only seems to go to about 20-30% utilization and a speed of 1.3-1.38 GHz which causes my R9 380 to only use about 40% of its power. I do not believe it as ram as I have 8 gigs and it never goes over 65%. This includes Fallout 4, The Forest, Battlefield 3, Crysis 3, and War of Thunder and some others. I have tried to force it to clock up via MSI Command Center but does not seem to help with the frame rate which is only about 25-30 FPS.
https://linustechtips.com/topic/556541-problem-with-cpu-not-using-full-potental/
Check your power options and make sure they're set to high performance.
Novus Anima
CPU - 4670K @ 4.2 GHz | Motherboard - ASUS Z97-PRO | CPU Cooler - Corsair H105
RAM - Corsair Vengeance (4x4GB) | GPU - EVGA GTX 1060 SSC
Storage - Samsung M.2 64GB SSD, PNY 240GB SSD , WD 1TB Caviar Blue, WD 500GB HDD
PSU - EVGA 650W G2 | Peripherals - Logitech G710, Logitech G602
Laptops
MacBook Pro Mid-2011
Surface Pro 3
57 minutes ago, Jam2 said:
Under Windows 10's power settings it is set to high performance
What MOBO are you using? and have you overclocked? Could be VRM throttling.
LanSyndicate Build | i5-6600k | ASRock OC Formula | G.Skill 3600MHz | Samsung 850 Evo | MSI R9-290X 8GB Alphacool Block | Enthoo Pro M | XTR Pro 750w | Custom Loop |
Daily | 5960X | X99 Sabertooth | G.Skill 3000MHz | 750 NVMe | 850 Evo | x2 WD Se 2TB | x2 Seagate 3TB | Sapphire R9-290X 8GB | Enthoo Primo | EVGA 1000G2 | Custom Loop |
Game Box | 4690K | Z97i-Plus | G.Skill 2400MHz | x2 840 Evo | GTX 970 shorty | Corsair 250D modded with H105 | EVGA 650w B2 |
